First let me say I am highly experienced with lane keeping assist and lane centering systems. I have had both types on my Hondas, Fords and my new Tesla. So our first road trip took place this last weekend from Orlando to Atlanta. I finally was able to settle in and use the cruise control and eyesight. On the new 2021 models it is actually a lane centering system. While using the lane centering system, I keep my hands on the wheel as required. About 1 hour into the trip I notice the system is trying to pull to the right even though I am centered in my lane. It feels like a lot of pressure on the steering which is strange. Suddenly I sneeze and let one hand off the steering wheel and the Ascent VIOLENTLY pulled to the right and went over the markers into the right lane (I was in center lane of 3 lane freeway). Is was terrifying! Had a car been in that lane I would have hit it. So now being more prepared I try to replicate it. And again it happens! I feel a sudden build up of pulling to the right and with hand relaxation in my steering grip the Ascent wants to violently overcorrect to the right paying no attention to lane markers. I finally had to turn off the lane ceneting function. I had my daughter record a video that I will take to Subaru to have it checked out but I already know this will not be a simple fix.
I've noticed that this is the way the lane assist operates:
It does NOT center you between the lines on the left and the right side of the vehicle. It will focus on one side and pull the vehicle in that direction until it lines up appropriately with that side of the lane. Once it lines up with that side it changes focus to the other side and steers the vehicle in that direction. It continues this left/right steering focus as long as you have the lane assist feature enabled.
It will keep you between the lines but, it makes you look like a drunk driver while it operates.
It has no regard for the side sensors that tell you another vehicle is beside you or passing you. If a car is passing me on the left but, my "Eyesight" is trying to "lane assist" me in that direction, my natural instinct is to pull to the right to allow the car to pass safely.
Once the other car has passed me, if I relax my struggle against lane assist, it will veer in that direction. It will cross the lane lines then flash the lights on the heads-up display and beep as though I've somehow screwed up.
The programming needs a serious firmware update.
Don't trust it.
Also, the adaptive cruise control works fine as long as the vehicle in front of you is captured by the "Eyesight" lenses while in motion.
Don't try that when you're coming up on a stopped vehicle. It won't even see it.
Example: Every night I take the freeway home. The Adaptive cruise control works beautifully until I exit the freeway. Coming down the off ramp I have to slam on my brakes if there is a car or truck stopped at the light at the end of the ramp.
In normal traffic, the car will stop if the vehicle in front of it stops. If it approaches an already motionless vehicle. You'd better hit the brakes.
