If you haven't heard about it, it only means you are uninformed, feel free to do your own research, it's been reported everywhere, on these boards, other online boards, objective Subaru excperts on various platforms.
If you haven't heard about it, it only means you are uninformed, feel free to do your own research, it's been reported everywhere, on these boards, other online boards, objective Subaru excperts on various platforms.Hmmm, I have not heard of oil leak issues. Per 100,000 ascents, how many had oil leaks reported? Please include your source. Thanks !
I’m glad to see you acknowledge this is an issue at least. Nobody knows the true numbers but I’ve seen enough threads on this forum alone to know that it’s not uncommon. Perhaps this was an issue with early models and isn’t now, but I have seen issues with 2019-2022 Ascent models.I never said the issue doesn't exist. I have repeatedly said it does.
Definitely not uncommon - but not the rampant problem some want to claim it is.I’m glad to see you acknowledge this is an issue at least. Nobody knows the true numbers but I’ve seen enough threads on this forum alone to know that it’s not uncommon. Perhaps this was an issue with early models and isn’t now, but I have seen issues with 2019-2022 Ascent models.
Not really. Probably less likely, since it's not a top down design where everything tries to flow into the oil pan. But us having an upper and lower oil pan may make up for that?I’m not saying other manufacturers aren’t using liquid gasket maker because many of them are. However, the potential for oil leaks with Subaru FA series engines is greater due to how they’re designed and also in part because of their boxer design.
Indeed - and especially not just because of I4 vs Boxer, but also because most cars use transverse mounted engines, so, the exhaust doesn't go under it like a "cradle" - unlike Subaru's.What perhaps exacerbates the issue is the fact that the exhaust manifold is so large (again due to the boxer design) that any oil leaking and pulled by gravity will more often than not find its way onto the exhaust manifold where it burns and is thus detected by the driver. This may not be the case with inline 4 cylinder engines where such leaks might go undetected for a much longer period of time.
The new steel type ones have not exhibited the problem, fortunately, but, regardless, it's cheap insurance and an easy installation.... I even made a vid that though inspired by the hose design change TSB, delves into the PCV valve so everyone can see how easy it is to do the replacement...A faulty PCV valve would no doubt be a huge contributor and since the PCV valve is not considered a maintenance item, it’s easy to be overlooked. Many users on here have reported theirs to be plugged.
True. When I've referred various social media discussions to this board and specific threads on this board, my posts have been deleted (hence the most popular posters, not the most accurate posters prevail).the vast majority of Ascent owners don’t know these boards exists,
why would customers paying for repairs hurt Subaru’s bottom line?
I've been retired for quite a few years so my numbers are just guestimate but you'll get the idea. In the tech industry and aerospace for 40 years where the consumer investment was in the millions, sometimes billions of dollars, we fought hard to win customers and then keep costumers. We'd say things like it's 20 times harder to win a customer than keep a customer. Said another way, every unhappy customer takes 20 more along with them. In the age of social media, every negative post is lost sales with direct impact on the bottom line.negative publicity of the type of problem that you erroneously think is happening, would be a big harm to their bottom line
I'm old enough to have been the gas jockey doing those checks and top-offs. BTW there were NO leak-free engines or transmissions in cars from the 50s, 60s and 70s. When I came home from work I looked like I spent the day on an oil rig.I still remember the days of when a stop for gas (every stop for gas) included checking fluids, including oil
It's one of the reasons I won't fix a slow leak. The factory applied the RTV by robot, the repair tech is going to do it by hand. Unless I'm the one doing the repair, I'll let it leak.manufacturers, regardless of which is best, are using liquid gaskets, in part because a computer can do all the sealing work, vs a human installing a physical gasket.
I had a BMW 325. When it was off the 3-yr warranty, I took it to an independent garage for service. They told me "just so you know that your car is leaking oil, but all BMWs do." My Odyssey leaked too, oil and power steering build, at Year-8. of owner shipOil pan leaks are "well known issues" since the creation of the automobile.
my 2021 Ascent has 35K or so miles (I forget the exact amount). I took it in to the dealer for an oil change, they found both the engine seal and oil pan gasket leaking. Car was out of commission for over a week while they repaired. The tech there told me the factory applied seals or garbage. Huge issue. My 2002 WRX had 345k miles on it, no oil leaks. 🤷🏽♂️If you haven't heard about it, it only means you are uninformed, feel free to do your own research, it's been reported everywhere, on these boards, other online boards, objective Subaru excperts on various platforms.
I'm dubious about what any technician says that takes over a week to reseal a liquid gasket. 😉my 2021 Ascent has 35K or so miles (I forget the exact amount). I took it in to the dealer for an oil change, they found both the engine seal and oil pan gasket leaking. Car was out of commission for over a week while they repaired. The tech there told me the factory applied seals or garbage. Huge issue. My 2002 WRX had 345k miles on it, no oil leaks. 🤷🏽♂️
A tech I trust at my local dealership has indicated the same.The tech there told me the factory applied seals or garbage. Huge issue.
24 hours. Not a week or more. That's per both the product specs and the service manual.A tech I trust at my local dealership has indicated the same.
A successful reseal requires a lot of work that involves ensuring the mating services are perfectly clean and free of contamination, applying the sealant consistently and in the right quantity followed by the proper amount of cure time prior to starting the engine.
It certainly shouldn’t take a week to carry out the repair. However, I would much prefer a dealership that tells me a week versus the dealership that tells me it can be done in the same day.24 hours. Not a week or more. That's per both the product specs and the service manual.
Labor is 3-5 hours for lower alone, 10.5 for upper alone, 11.5 for both. And those are conservative figures.
Some shops with inexperienced techs quote an absurd 30 hours for just the upper. I wonder if they're charging labor for the time it's sitting curing.
Heck yes!!!! I fight against that nonsense whenever it comes up. The hood bonding issues was one such where they'd return the car in a few hours instead of keeping inside curing overnight. I reported a couple of dealerships for doing that disservice to owners.It certainly shouldn’t take a week to carry out the repair. However, I would much prefer a dealership that tells me a week versus the dealership that tells me it can be done in the same day
I think that this is something that virtually nobody truly understands. Just because the actual repair time is "X" hours, doesn't mean your car will be ready to go at X+5 minutes. And also that your car is not being worked on every second it's in the shop (for a whole variety of good or understandable reasons).It certainly shouldn’t take a week to carry out the repair. However, I would much prefer a dealership that tells me a week versus the dealership that tells me it can be done in the same day.
I’m guessing the dealership told the customer a week to be on the safe side and allow some buffer, which in my view is prudent. Any dealer will obviously have a workload and it’s easier to promise a customer a seven day completion than to try to rush the job in a couple of days while juggling other jobs.
Nobody has ever said “hey, that sealant was allowed to cure for too long!”
It reads like every discussion of statistics vs crowd sourced data ever debated.I halfway step out for a weekend and nearly miss this gem of a thread… 😳 🤣
Since AI can’t lie to us (take that with a grain or two of salt), here’s the final answer:
I have to agree.Feel free to explain why he is wrong, why miles of cheap RTV is actually the best gasket material and provide stats disproving any of these claims.
The fact that you’re laughing at hundreds and thousands out of a tiny population shows how you are not interesting in objectively. These are not hundreds or thousands out of 3/4 of a millions owners, it is hundreds and thousands out of hundreds and thousands of people who would be willing to write about it in these forums. For every one that posts there can be 10s, 100s or 1000s of owners sitting there and thinking that’s exactly what happened to them. Basic concepts of statistics.
Again, Subaru doesn’t release this data so obviously nobody can prove this with official data, but what we do have is A LOT of anecdotal evidence and logical and technical explanation as to why this is happening. LOLing and calling names is not a valid disproval, it just shows that there is no valid argument against it.
I think the pool of people who are clearly having these issues is large enough to warrant some pause and consideration.For those who never ever heard about oil leaks in the Ascent, you don't need to look far, these are a lot of complaints for such a new vehicle.
But there is just no evidence that oil leak is a major problem with the 23. Several of us keep quoting Consumer Reports because they systematically track reliability issues over a long period of time and the Power train in the Ascent has been "better than average" since the 2021 model year. There is not even enough personal anecdotal evidence to support this claim here—given the number of Ascent sold yearly, 50,000 (per ChatGPT), I have not seen any complain on oil leak in this forum. May be I miss it but I come here once a day so it the complains are so rampant, I would have seen it regularly. I have a 23 but I dont here to tell people all the problems I don't have.I think the pool of people who are clearly having these issues is large enough to warrant some pause and consideration.
The bury your head in the sand method is short sighted.
There have been a number of posts about leaks, but it's not a "yuge" number and not likely out of line with the industry that moved to the gloop-on sealing material rather than old fashions fiber/composite gaskets.I have not seen any complain on oil leak in this forum.
