The Ascent's turbine is also sized according to the exhaust flow in the desired rpm range. This is what helps the turbo spool so quickly, but also what limits the flow at higher rpms.
It seems Porsche is taking the idea of a turbo and splitting it up, kind of genius in a way, removing the compressor makes the turbine more efficient and removing the turbine makes the compressor less dependent on RPM. If it works correctly, which I'm sure at this stage it will, it could be a step for ICE to electrification. The turbine uses waste energy to power the compressors exactly like a standard turbo without lag or unnecessary heat transfer.
