I am thinking of buying wheel/tire setup for TireRack. Does anyone know what we need to do to be able to keep TPMS working on winter tires? Obviously I do not want to move my TPMS sensors from 1 wheel set to the other.
its how it is in some cars ... but they don't have independent readers in or near the wheel wellsI don't know.
I remember reading about another car having to register the sensors in a particular order so that the car would know which was which.
Ha. I didn't know this. On my search I can not find anywhere it says Subaru Ascent has TPMS in Canada while a lot of articles say Subarus didn't have this in the past. I will ask my dealer.I thought the Canadian Subarus (all, not just Ascents) don't come with TPMS? You are in Ottawa, Canada so you shouldn't worry about TPMS unless you imported a US-spec Ascent.
TPMS are mandated in the United States, thanks to Ford, and sadly to the people who got hurt or died. The TREAD Act was enacted by Congress in 2000, effective for 2008 and newer model years, after rollover incidents involving the Ford Explorer and Firestone tires.Ha. I didn't know this. On my search I can not find anywhere it says Subaru Ascent has TPMS in Canada while a lot of articles say Subarus didn't have this in the past. I will ask my dealer.
Thanks for pointing out.
Thanks for your insight. Yes, that make sense and that's what my assumption too. So I popped a question to dealer and waiting for the answer. My delivery is on next Wednesday. But I am waiting on this to decide to buy either 20" winter tires alone or 18" tires and rims.SHORT VERSION:
TPMS is mandated in the United States, but not Canada. Vehicles made for sale in Canada may or may not have TPMS depending on whether or not the manufacturer decided to do a slightly different spec vehicle for Canada.
My understanding is that theoretically, if you get an Ascent that was slated for the US market, but delivered to Canada, it would have the TPMS, unless they took the time to swap wheels. If you got an Ascent that was slated for the Canadian market but got it in the US, then they definitely swapped to wheels with TPMS as required by law when the vehicle is re-assigned as a US vehicle.
I had no idea that Canadian Subaru's didn't have TPMS until I took my Ascent home and started playing with it. I thought that was a total given these days. I am really not pleased with this omission, but it seems that there is nothing that can be done about it at this point. It has come in handy several times in the past 8 years with my Acadia on the kinds of roads that I drive.
I am bit surprised, but don't think it is big issue. Even when I had it, I didn't trust the Honda TPMS that much. It never warn me of anything in last 8 years. But I do fill nitrogen every couple of months and with Costco nitrogen inflation facility it is pretty easy. Just set the required tire pressure ( or ask any service guy in the Tire center) and inflate the tire. When the tire pressure reaches the value set, it beeps. No need to for check the pressure with an external tool.I'm surprised as well. It seemed standard on much cheaper vehicles so I just assumed
The only reason I can see leaving it out is that winter tires are mandatory in a lot of places and most people don't spend the money to add sensors to their winter rims so almost everyone spends 4-6 months out of the year with the warning light on
I'm so used to ignoring it I'm not sure it would even catch my attention unless it came on while I was driving
Tire Rack now showing
Autel MaxiTPMS TS508 to be compatible with our sensors
or
Autel MaxiTPMS TS508K comes with 4X 433 sensors and you can clone it to you factory sensors
There's something odd/different with the programming though. The Subie performance shop I went to tried those profiles, and they didn't work. Please keep me posted.more info from the maxitpms site
no Ascent listed yet but 2018 Impreza and Crosstrek listed on all points and if i see it correctly Ascent TPMS is same
OBD-II Function
Programming Status
Supported by Autel(MX-Sensor)
Supported by Autel(Tool) (OBD-II)
P.S..If the "Relearn Type" of MX-Sensor is only OBD type, and the "OBD-II Function" has not been released for the moment, you can just do the clone for relearning the MX-Sensor.
how long ago was it ? tool FW need to be updatedThere's something odd/different with the programming though. The Subie performance shop I went to tried those profiles, and they didn't work. Please keep me posted.
TPMS readings are not adjustable... how do you know its 35 and not 31 ? its odd to have all 4 to be off exactly the sameMy TPMS says 31 psi in all 4 but it really has 35. How do I reset it. No new tires it just displays wrong psi
2018 Impreza and XV Crosstrek was listed under 315, on last update they added 433 profile
also is the key word "added" as it still 2018 XV Crosstrek listed 315 but 2018 Crosstrek listed 433
I think one shows 30 and the other 3 31. Manual tire gauge says all 4 around 35-36. I would of thought I would get a low air condition since the recommended pressure is 35TPMS readings are not adjustable... how do you know its 35 and not 31 ? its odd to have all 4 to be off exactly the same
BTW Subaru only update as you drive
One thing I've noted is that the tires increase pressure by nearly 4psi (+/-) from driving even short distance due to warming up. Presuming you've checked both readings at the same time, so...I think one shows 30 and the other 3 31. Manual tire gauge says all 4 around 35-36. I would of thought I would get a low air condition since the recommended pressure is 35
