61 - 71 of 71 Posts
The Problem: New Ascent (about 50 miles on it) I tried to open the tailgate from driver seat. The car's new and I'm just learning so I fumbled with the button pressing and releasing twice in rapid succession. Tailgate made clunk sound and then got a high-pitched beep that would not stop. Tailgate appeared in closed position. No idiot lights or messages on console. Could not open the tailgate manually or with key fob. Beep would not stop. Car seemed to be OK otherwise. It would start, drive, park, and lock and unlock OK. Tailgate kaput.
The Solution: I disconnected both battery leads and touched the leads together for several seconds. When the leads were disconnected the beep (of course) stopped. After touching leads together I reconnected them to the battery and the beep did not return. At this point the tailgate worked fine and all is sweetness and light.
The Explanation: So the service manager explained that the tailgates are finicky beasties and have special logic in them that tries to prevent motor burn out should the gate be opening and closing at the same time (double button push?). Once the gate gets into a "safety mode" it will not open or close and just sits there like a lox complaining with a beep sound. Doing the battery dance resets things sort of like CTRL-ALT-Delete for the car.
Subaru: It sure would be nice to have (a) An indicator showing that the tailgate is in this mode and (b) A way to reset that does not require a metric socket set and some mechanical aptitude.... just say'n....
Thanks for your post. I had the same problem occur. I didn’t have to disconnect both leads. I only removed the negative lead and that fixed the problem.
Stuck open and stuck closed both need separate reset procedures.
See my previous posts here:
This was the first forum post I found today when my Ascent did this exact thing! Took me 2 min and a 10mm wrench and it’s fixed! THANK YOU!!!!
Good info thanks. Last time I eventually disconnect the negative battery lead. This time was different. I accidentally closed the rear door from the front while by dogs leash was hooked to the tailgate and it was jammed. 500km later I read this forum and did the 10 second tailgate button reset. It worked!
61 - 71 of 71 Posts
