Hi all,
2019 with 123k on the clock
Just started to get the "Christmas tree" on my dash.
No transmission stutters, gas cap on
Recalls done (90% sure)
Ideas?
I've cleared them, but wondering where I should point my wallet to fix it
Ideas?
Code:
Car Scanner ELM OBD2
Version: 1.101.4/401014/GP
DTC report
Connection profile: Subaru 2010-n.d. CVT/AT with CANDate: 12/4/2023 9:58:26 PM
VIN: removed for privacy
OBD-IIOBD-II
DTCs: 2
P0700 [0x0700]
Transmission control system, MIL request - circuit malfunction
Status: Confirmed
P0841 [0x0841]
Transmission fluid pressure (TFP) sensor A - range/performance problem
Status: Confirmed
Engine control unitEngine control unit
DTCs: 1
P0700 [0x0700]
Status: Pending, Confirmed, Test failed since last DTC clear
Transmission control unitTransmission control unit
DTCs: 1
P0841 [0x0841]
ABS control unitABS control unit
DTCs: 1
C1431(00) [0x543100] Archive (inactive)
Status: Confirmed
BCM
No DTC found.
SRS/Airbag
No DTC found.
A/C, Heater), ClimateA/C, Heater), Climate
DTCs: 1
B14A1(00) [0x94A100]
Status: Test failed (current drive cycle)
Dashboard
No DTC found.
Display
No DTC found.
Headlights
No DTC found.
Keyless access
No DTC found.
Occupant detection
No DTC found.
Power steering
No DTC found.
TPMS
No DTC found.
