1 - 20 of 24 Posts
Hey all, as many of you know, I've been in contact with the developers of ActiveOBD. You've all gotten your iPhone app (with neat new graphics, no less), and now they're considering going back to the Android App to do some more updates.
PLEASE HELP!!!
They are trying to gauge interest for the Android app.
PLEASE go to this Twitter link and show your support!!!
NEW interface on the left, OLD interface on the right
5639
@smart_alec thanks! Also, there's an iPhone version now too... needs a WiFi OBD2 adapter, but works well I've heard.
If I can use with my old OBDLink LX and deactivated Android Phone, I will test it out on my Forester (or OB)
@pilot1226 should work fine. That's a fully supported setup. I've been thinking of permanently mounting one of my older Android devices for that (and maybe even maps, since I have the hotspot).
I’m an iPhone guy, but I’ll try to drum up interest!
the link won’t open for me. Do you have to be a Twitter user?
Shouldn't need to be. Worked in Incognito Mode for me. The iPhone may be looking for the Twitter app, or you may have it installed and never ran. If that's the case, you can see it on desktop, and copy/paste the link to share.
fyi, I received the response below.
Thank you for reaching out I am happy to help.
MX+ will read and clear generic diagnostic trouble codes and read generic live parameters for all 1996 and newer cars and light trucks sold in the United States, including Subaru vehicles
Unfortunately, the included OBDLink app does not support reading enhanced diagnostics such as transmission temperature for Subaru vehicles at this time. :(
However, thanks to MX+'s open architecture, it is compatible with many third-party apps and software!
Users have reported success with Subaru specific apps such as “BtSsm” and “ActiveOBD for Subaru” in order to view enhanced diagnostics for their vehicles.
I would suggest contacting the app developers to confirm support for your specific model and year :)
from activeobd: ActiveOBD for Subaru - Apps on Google Play reviews indicate it is very temperamental, so I really do not know what to make of it.
PLEASE HELP!!!
Please for the love of GAWD make this today! I will pay serious money. Can it do boost pressure, manifold and exhaust temps too? I tow with my Ascent and all this telemetry would be fantastic.
It definitely does exhaust/cat temps, knock, engine oil temps, errors/faults, etc. And data logging for later review. The other data points are on other screens, which are an easy swipe left/right to get to.
So, @Baldman64 if you haven't already, please go to the OP and click the Twitter link and let him know you're interested in continued Android development. ;)
Discussion Starter · #12 ·
I use the Scangauge MX. The MX+ should have the same capabilities as the MX. Which one do you have and what app are you using them with? Torque is pretty forgiving, and you can turn down speed and enable ELM327 mode. ActiveOBD requires certain adapters.
Discussion Starter · #14 ·
Cheap OBD2 is barely "compatible". I tossed mine. I used it, with occasional issues, with my 2010 Outback. With my Ascent, it was a pain to get it to work (slow down communication in Torque, limit command set, and select ELM327 compatible), but, even then, it would regularly flake out and lose connection to the car, or stop sending data. I bought it to replace my original ScanTool that I broke.
5695
I gave up on using it in the Ascent, after a few weeks, and bought another ScanTool.
5696
I downloaded the app from his twitter feed and it has the old look. Has he released the new look for Android as yet?
I had an old Carista OBD dongle I plugged in and it showed, Water Temp, Oil Temp, CVT ratio, but center drive line % never showed any info. Second page, it showed AT oil temp, Inlet air Temp, No intake manifold temp, Cat temp. Third screen, showed Fuel level percent, No fuel consumption reading, No IGn advance multiplier, No Learning knock Correction, No ignition learned timing, but did show Ignition Total timing.
This dongle is about 8 years old and I'm sure newer ones will capture more info for the App to display. Will order a new dongle as soon as things get settled out which one does the best job.
BTW live data from Autel MaxiAP AP200 , it can see 20+ modules
here are readings from first 2..
Engine
0​
Engine Speed
822​
rpm
1​
Mass Air Flow
0.01​
lb/s
2​
Vehicle Speed
0​
mph
3​
Throttle Opening Angle
14​
4​
Accel. Opening Angle
0​
5​
A/F Sensor #1
1​
6​
Ignition timing adv. #1
2​
7​
Coolant Temp.
141.8​
°F
8​
Fuel Injection #1 Pulse
1.54​
ms
9​
Short term fuel trim B1
-3.1​
10​
Long term fuel trim B1
-7​
11​
Learned Ignition Timing
0​
deg
12​
Mani. Absolute Pressure
5.37​
psi
13​
Oxygen sensor #12
0.85​
V
14​
VVT Adv. Ang. Amount R
0​
deg
15​
VVT Advance Target Angle Amount R
0​
deg
16​
VVT Adv. Ang. Amount L
-1​
deg
17​
VVT Advance Target Angle Amount L
0​
deg
18​
Exh. VVT Retard Ang. R
0​
deg
19​
Ex VVT Retard Target Angle R
0​
deg
20​
Exh. VVT Retard Ang. L
-1​
deg
21​
Ex VVT Retard Target Angle L
0​
deg
22​
VVT Initial Position Learning Value #1
76.5​
°CA
23​
VVT Initial Position Learning Value #2
78.8​
°CA
24​
VVT Ex Initial Position Learning Value #1
108.3​
°CA
25​
VVT Ex Initial Position Learning Value #2
108.6​
°CA
26​
Number of Cleaning Executions for VVT Self -recovery
0​
Time
27​
Number of Cleaning Executions for Ex VVT S elf-recovery
0​
Time
28​
Control module voltage
14.312​
V
29​
Target engine speed
880​
rpm
30​
Target Equivalence Ratio
0.998​
31​
Oil Temperature
134.6​
°F
32​
IAT Sensor #11
78.8​
°F
33​
IAT Sensor #12
91.4​
°F
34​
Ambient Temperature
42.8​
°F
35​
Calculated load value
45.1​
36​
Absolute Load Value
25.5​
37​
Atmosphere Pressure
14.5​
psi
38​
Mani. Relative Pressure
-9.28​
psi
39​
Electric Waste Gate Valve Position Sensor Learning Value at the Full-closed Position
0.008​
inch
40​
Electric Waste Gate Valve Request Position Value
0.591​
inch
41​
Electric Waste Gate Valve Actual Position Val
0.588​
inch
42​
Electric Air Bypass Valve StatusClose
43​
Target Throttle Opening Angle
5​
deg
44​
Actual Throttle Opening Angle
5​
deg
45​
5.9​
46​
Relative Throttle Pos.
3.9​
47​
Throttle Motor Voltage
13.8​
V
48​
Main-Throttle Sensor
0.7​
V
49​
Sub-Throttle Sensor
0.76​
V
50​
Throttle Motor Duty
-22​
51​
Main-Accelerator Sensor
0.66​
V
52​
Sub-Accelerator Sensor
0.66​
V
53​
Idle Mass Air Flow
0.02​
lb/s
54​
Idle Mass Air Flow Feedback correct
0​
lb/s
55​
ISC Learning Value
0​
lb/s
56​
Idle A/C load correct
0​
lb/s
57​
Electric Load Feedback Val
0​
lb/s
58​
Idle dirty throttle correct
0​
lb/s
59​
Fuel Rail Pressure A
419.16​
psi
60​
Fuel Rail Pressure B
423.51​
psi
61​
Commanded Fuel Rail Pressure A
438.01​
psi
62​
Commanded Fuel Rail Pressure B
438.01​
psi
63​
Fuel Level
71​
64​
Fuel level resistance
122​
ohm
65​
Fuel Pump Duty
75​
66​
Commanded Evap Purge
0​
67​
CPC Valve Duty Ratio
0​
68​
Purge Density Learn Value
0​
69​
Evap Purge Flow
0​
70​
Purge Line Pressure
14.32​
psi
71​
ALT Duty
71​
72​
Alternator control modeHigh
73​
Battery Terminal Voltage
14.3​
V
74​
Battery Charge/Discharge Current
3.8​
A
75​
Estimated Battery Temperature
74.3​
°F
76​
Remaining Battery Capacity
99.2​
77​
Knocking Correction
0​
deg
78​
Fuel system for Bank 1Cl_normal
79​
A/F Sensor #1 Current
0​
mA
80​
A/F Sensor #1 Resistance
154​
ohm
81​
A/F Correction #3
-1.56​
82​
Front O2 Heater #1
1.45​
A
83​
Rear O2 Heater Current
1.25​
A
84​
Rear O2 Sensor Input Voltage
2.745​
V
85​
Rear O2 Sensor Offset Voltage
1.995​
V
86​
No. of EGR steps
0​
STEP
87​
Commanded EGR
0​
88​
EGR Error
0​
89​
TGV Position Sensor R
1.1​
V
90​
TGV Position Sensor L
1.06​
V
91​
TGV OutputOFF
92​
TGV DriveClose
93​
OCV Duty R
52.5​
94​
OCV Duty L
52.2​
95​
OCV Current R
704​
mA
96​
OCV Current L
704​
mA
97​
Exh. OCV Duty R
43.1​
98​
Exh. OCV Duty L
43.9​
99​
Exh. OCV Current R
544​
mA
100​
Exh. OCV Current L
576​
mA
101​
Roughness Monitor #1
0​
102​
Roughness Monitor #2
0​
103​
Roughness Monitor #3
0​
104​
Roughness Monitor #4
0​
105​
Cylinder Monitor #1
880​
rpm
106​
Cylinder Monitor #2
835​
rpm
107​
Cylinder Monitor #3
828​
rpm
108​
Cylinder Monitor #4
819.75​
rpm
109​
Trip Count
474​
Time
110​
CountCommon
111​
Time Count
524800​
ms
112​
Time Since Engine Start
526​
sec
113​
Elapsed Time After Engine Run
527​
sec
114​
Accumulation Time After Engine Run
531​
sec
115​
Initial Engine Oil Temp.
86​
°F
116​
Initial Engine Coolant Temp.
89.6​
°F
117​
Initial Intake Air Temp.
77​
°F
118​
Engine Starting Time
680​
ms
119​
IG OFF Elapsed Time
9283​
sec
120​
Meter since DTC(s) cleared
2937.22​
miles
121​
Time while MIL lighted
0​
min
122​
Time since DTC(s) cleared
5678​
min
123​
Number of warm-ups
135​
Time
124​
Lighted MI lamp history
0​
miles
125​
Odometer
2927.9​
miles
126​
Maximum Engine Speed at the time of Misfir e detection caused by out of Fuel
0​
rpm
127​
Maximum Intake Air Amount at the time of M isfire detection caused by out of Fuel
0​
lb/s
128​
Number of Misfire detection caused by out o f Fuel
0​
Time
129​
Estimated Total Mileage at the time of first M 0.00 isfire detection caused by out of Fuelmiles
130​
Engine Speed at the time of Detection to avo 0 id Preignition caused by out of Fuelrpm
131​
Intake Air Mass at the time of Detection to a void Preignition caused by out of Fuel
0​
lb/s
132​
Number of Preignition Detection caused by out of Fuel
0​
Time
133​
Estimated Total Mileage at the time of first D etection to avoid Preignition caused by out o f Fuel
0​
miles
134​
Status of Control to avoid Pre-Ignition cause d by Continuous KnockingOFF
135​
Estimated Total Mileage of Detection to avoi d Pre-Ignition caused by Continuous Knocki ng
0​
miles
136​
Cruise Control System Setting ConditionOFF
137​
Cruise Control System Request Torque
0​
lbf ft
138​
Driver Request Torque
28.313​
lbf ft
139​
Fuel Cut Elps Time
0​
sec
140​
Memorized Cruise Speed
0​
mph
141​
Catalyst Temperature #11
732.56​
°F
142​
Type of fuelGAS
143​
AT drive statusNEUT
144​
Absolute Evap Sys. Pressure
14.47​
psi
145​
X modeOFF
146​
Neutral Position SwitchNeutral
147​
ETC Motor RelayON
148​
Stop Light SwitchOFF
149​
Brake SwitchOFF
150​
Idle Switch SignalIdle
151​
Ignition SwitchON
152​
A/C Compressor SignalON
153​
Radiator Fan Control
43​
154​
Radiator Fan1 Monitor Duty
35​
155​
Radiator Fan2 Monitor Duty
36.8​
156​
A/C SwitchOFF
157​
Variable Load Compressor Torque Value
0​
lbf ft
158​
Starter SwitchOFF
159​
Rear Defogger SWOFF
160​
Blower Fan SWON
161​
Light SwitchON
162​
Wiper SwitchOFF
163​
Delivery Mode ConnectorOFF
164​
Rear O2 Rich SignalLean
165​
Knocking SignalOFF
166​
Crankshaft Position Sig.ON
167​
Camshaft Position Sig.ON
168​
Ban of Torque DownON
169​
Request Torque Down VDCOFF
170​
Torque Permission SignalON
171​
SET/COAST SwitchOFF
172​
RESUME/ACCEL SwitchOFF
173​
Main SwitchOFF
174​
distance change SWOFF
175​
CC Cancel SWOFF
176​
All Cylinders Fuel cutOFF
177​
Immobilizer Fuel Cut StatusOFF
178​
Shift Pattern Demand for Low Water Temper atureOFF
179​
Oil level switchHIGH level
180​
ELCM switching valveOpen
181​
ELCM pumpOFF
182​
AT turbine speed
768​
rpm
183​
Lock up statusOPEN
184​
P/N SignalON
185​
Blow-by leak ConnectorConnect
186​
Ignition Control Check 1
90​
187​
Ignition Control Check 2
31​
188​
Alternator control check 1
57.5​
189​
Alternator control check 2
49.5​
190​
Alternator control check 3
6.8​
191​
Alternator control check 4
5.81​
192​
Alternator control check 6
1​
193​
Alternator control check 7
14.3​
194​
Alternator control check 8
3​
195​
Alternator control check 9
64​
196​
Alternator control check 10
16​
197​
Alternator Control Check 11
-378​
198​
Alternator Control Check 12
154​
199​
Alternator Control Check 13
2.95​
200​
Alternator Control Check 14
8217​
201​
Alternator Mechanical Error StatusOFF
202​
Alternator Electrical Output Error StatusOFF
203​
Alternator High Temperature Error StatusOFF
204​
Alternator Communication Error StatusOFF
205​
Regulator Temperature
154.4​
°F
206​
ETC Functional Safety Check 1
0​
207​
ETC Functional Safety Check 2
0​
208​
ETC Functional Safety Check 3
255​
209​
255​
210​
0​
211​
0​
212​
Functional Safety Check 4
255​
213​
Functional Safety Check 5
0​
214​
Functional Safety Check 6
255​
215​
Functional Safety Check 7
0​
216​
Crush Detection SignalOFF
217​
MIL StatusOFF
218​
0​
219​
O2 Sensor #11Supported
220​
O2 Sensor #12Supported
221​
Short term fuel trim #12
0​
222​
A/F Sensor #11
0.974​
223​
A/F Sensor #11
2.063​
V
224​
A/F Sensor #11
0.986​
225​
A/F Sensor #11
2.54​
mA
226​
Absolute Throttle Pos.#2
14.5​
227​
Accelerator Pedal Pos.#1
13.7​
228​
Accelerator Pedal Pos.#2
13.7​
229​
Relative Accelerator Pos.
0​
230​
Misfire monitoring(Supp)YES
231​
Misfire monitoring(Rdy)YES
232​
Fuel system monitoring(Supp)YES
233​
Fuel system monitoring(Rdy)YES
234​
Component monitoring(Supp)YES
235​
Component monitoring(Rdy)YES
236​
Catalyst Diagnosis(Supp)YES
237​
Catalyst Diagnosis(Rdy)YES
238​
Heated catalyst(Supp)NO
239​
Heated catalyst(Rdy)N/A
240​
Evaporative purge system(Supp)YES
241​
Evaporative purge system(Rdy)YES
242​
Secondary air system(Supp)NO
243​
Secondary air system(Rdy)N/A
244​
A/C system refrigerant(Supp)NO
245​
A/C system refrigerant(Rdy)N/A
246​
Oxygen sensor(Supp)YES
247​
Oxygen sensor(Rdy)YES
248​
O2 Heater Diagnosis(Supp)YES
249​
O2 Heater Diagnosis(Rdy)YES
250​
EGR system(Supp)YES
251​
EGR system(Rdy)YES
252​
Misfire monitoring(Enable)YES
253​
Misfire monitoring(Comp)YES
254​
Fuel system monitoring(Enable)YES
255​
Fuel system monitoring(Comp)NO
256​
Component monitoring(Enable)YES
257​
Component monitoring(Comp)NO
258​
Catalyst Diagnosis(Enable)YES
259​
Catalyst Diagnosis(Comp)NO
260​
Heated catalyst(Enable)N/A
261​
Heated catalyst(Comp)N/A
262​
Evaporative purge system(Enable)NO
263​
Evaporative purge system(Comp)NO
264​
Secondary air system(Enable)N/A
265​
Secondary air system(Comp)N/A
266​
A/C system refrigerant(Enable)N/A
267​
A/C system refrigerant(Comp)N/A
268​
Oxygen sensor(Enable)YES
269​
Oxygen sensor(Comp)NO
270​
O2 Heater Diagnosis(Enable)YES
271​
O2 Heater Diagnosis(Comp)YES
272​
EGR system(Enable)YES
273​
EGR system(Comp)NO
274​
OBD SystemOBD/OBD2
Transmission
0​
Engine Speed
808​
rpm
1​
Turbine Revolution Speed
768​
rpm
2​
0​
3​
Front Wheel Speed
0​
mph
4​
ATF Temp.
120.2​
°F
5​
Lock Up Duty Ratio
0​
6​
Actual Gear Ratio
2.43​
7​
Primary Rev Speed
786​
rpm
8​
Secondary Rev Speed
323​
rpm
9​
Front Wheel Speed
0​
rpm
10​
11​
Secondary Set Current
770​
mA
12​
Secondary Actual Current
772​
mA
13​
Commanded Forward & Reverse Linear Sole noid Current
1000​
mA
14​
Actual Forward & Reverse Linear Solenoid C urrent
1001​
mA
15​
14.275​
V
16​
Primary UP Duty
0​
17​
Primary DOWN Duty
38.8​
Discussion Starter · #19 ·
Not yet.
Everyone needs to make sure they post that they want it on the Twitter link in my OP (also below) so he knows there's interest, because they're considering dead-ending the Android app, due to how quiet we all are.
5799
Banned
2021 Ascent Premium
I think you meant OBDLink, not Scangauge (they don't have a product called the MX that I'm aware of).
As of testing tonight, the OBDLink MX+ did not allow me to see the AT/CVT temp or torque vectoring in ActiveOBD in my 2021 Premium. Other sensors were updating.
1 - 20 of 24 Posts
