1 - 7 of 7 Posts
· Registered
Hi!
I own an Acent limited since July 8th-and still dont know where my wifi password is! Its not in the paperwork, I signed on with AT&T and starlink. No clue where to find it. Help!
· Registered
Hi!
Turn on the wifi on your Ascent menu, then you'll see the hotspot menu underneath. That screen shows the wifi name and password.
· Registered
I used my 1G free trial in one week! I have AT&T as my carrier and would only cost $10./mo to add to my plan. Not sure it’s worth it. I never use that much on my phone so quickly. What actually is using the WiFi? I did have Apple play activated when my phone was hooked via cable.
· Registered
Anything that can use your home WiFi or the wifi hotspot on your phone can use the car's WiFi the same way except it is using your AT&T data plan.
The main advantage of this is your Ascent has a much larger antenna and more powerful cellular radio than your phone so you will have longer range and faster speed in locations where your phone may struggle to find a signal.
We use this during our cross country trips across the Southwest where there can be big gaps in cell service and it makes a big difference over just using the phone.
1 - 7 of 7 Posts
