1 - 9 of 9 Posts
Check here and make sure you set up the trial or service.
I would like to use my phone when I am in an area with no cell coverage so I would like to link through my 2019 Crosstrek.
You may want to ask over in the Crosstrek forums.
I believe that the vehicles still use cell towers as compared to a satellite link. The difference will be a stronger signal from the vehicle as compared to the cell phone (you can boost the cell phone signal with a booster or outside antenna). A car can use a MiFi but still you will need connect to a cell tower. You also will need to determine if you are looking for a mobile signal booster (while driving) or a stationary signal booster(like a camp site). The feds have set different limitations for each. If you are going on a road trip that you know will be challenging accessing a cell tower than you might consider renting a sat phone (see link above). Rental costs will depend on what you ultimately are trying to achieve.
The vehicle hot spot uses the ATT cellular network via a subscription you sign up for, so if there is no ATT cell coverage, the hot spot function isn't going to work beyond "inside the vehicle".
its like having another cell phone but looks like a car
i didn't get it or use the promotion
all my iPhone xr (ATT service) has hotspot at no "additional" charge and i can feed any other wifi thing out there up to ten items and share my connection share my data I use it mostly when i take my laptop
1 - 9 of 9 Posts
