1 - 8 of 8 Posts
Hey everyone! I’m looking for a little wider of a tire but I like the stock 20 inch wheels. I know they have a 7.5 inch width, so I was wondering if it could take a tad wider tire without rubbing.
Was looking at falken wildpeak but in a 255/50 R20
255s should work but 265s start to get tight, although I think some folks have tried them. Diameter matters, so the aspect ratio has to be factored in, too. Keep in mind that if you go to a larger diameter tire, you also have to do the same for your spare on and AWD vehicle and your speedo/odo will not be accurate.
Should be no problem for the 255/50R20 other than also needing to change the space to match the diameter.
That should read "Spare" tire.
The wider tire may increase your rolling resistance and decrease your fuel mileage , I tried a more aggressive tire on my Forester and experienced this , the CVT would not drop down to a tall ratio
1 - 8 of 8 Posts
