1 - 10 of 10 Posts
Did anyone experience whistling noise at freeway speeds? Test drove one today for purchase...and I noticed it...the sales person also was puzzled and was theorizing it could be due to the cross bars...
Not sure what might cause it, I had the moon roof inner cover pulled all the way back but the moonroof itself was closed. This one had the panoramic moon roof...
Could be lots of things causing a whistle like a small air leak. Sometimes they are easy sometimes hard to find. I think I would either have them fix it before I buy (easy)or pass. Good chance to find out if the service department is any good.
Improperly installed crossbars will definitely do that. I've seen quite a few installed backwards. The thick edge faces the wind. I've also seen a leaf stuck in a door opening, trim piece or hood cause it.
Cool thanks! Once I get mine...I will post a pic...hope you can tell me if if its right...if not I will switch it around :)
I actually did a vid, because I'd seen so many as I drove around (but, I will gladly check it out when you're done).
2019 Ascent Premier
When I bought mine in January mine also did that and it was the front crossbar. I removed the front one to make a test and the noise disappeared completely.
I left the back one installed in part for laziness and part because having only one installed made it really easy to find spot the car in busy parking lots ?
If you get bored, and want to do a test, try putting it back on with the thick Edge facing forward, and see how it sounds. Mine are silent. I have seen dealers installed one the proper direction and one the opposite direction, for whatever reason.
Could be a lot of things. If you can, try to have a passenger locate the general location of the noise by listening out of various windows.
I has such a whistle on my Forester when it was new that drove me crazy. It turned out to be a misaligned driver's side door which the dealer fixed. I never had it happen again for the next 10 years with that car.
I have a 2020 touring and it currently is at Subaru for the third time because of this noise. I do not have cross bars, the moon roof, hood, and doors have been checked. They are now exploring the striping/seals around the windshield. I hear it going 70-80 mph on the drivers side. I knew it would be a bit of a ride to try and figure it out! I can post an update if or when we get it fixed.
1 - 10 of 10 Posts
