1 - 12 of 12 Posts
I did. Keep in mind that you should not use them on aftermarket rims unless they also use 60° flat conical lug nuts.
B321SFL000
Just for anyone wondering, you can ignore the website saying it cannot confirm fitment.
Here's the original, which is replaced by the one above.
Yes, it fits all years to date (2019-2021) Ascents, all trim levels, STOCK rims or others with 60° flat conical lug nut surfaces.
2020 Ascent Limited
"Everyone" apparently uses McGard.
5937
B321SFL000 is the new part number. And, yes, it's a typo. Note the phone number.
5938
5939
This maybe neither there nor here, but I've been told that McGuard type locks are not gonna work against a thief who knows what he's doing. Apparently there's a way to remove the cover (if the system has one) and use vise grips or some other tool to remove the lug nuts.
There's no cover on ours that I noted, but, the super large vice grips and a breaker bar would probably work, simply because of all of the surface area to grip to. Works just the same as doing the same for a stripped lug nut. 😞
1 - 12 of 12 Posts
