Does anyone know the bolt pattern for the Ascent? Would like to shop around for some wheels but cant find what the bolt pattern is for the Ascent
And yes, need to know the stock offset, too, and rim width. Should be stamped on the inside of the rim.I am at demo tomorrow. I suspect it is 5-114.3, same as Outback, but need to confirm. I have a 3.6R Outback, going to measure that, then measure Ascent. I will have definitive answer tomorrow. Hoping that it is 5-114.3, that could mean STI wheels are in the cards.... Assuming offsets are appropriate.
I thought I remembered seeing the wheel size was 18x8 for premium and 20x8 for the limited/touring trims.And yes, need to know the stock offset, too, and rim width. Should be stamped on the inside of the rim.
Wheels are actually 7.5 inches wide in both 18 inch and 20 inch diameters.I thought I remembered seeing the wheel size was 18x8 for premium and 20x8 for the limited/touring trims.
Thank you for the correction! Didn’t mean to spread #fakenews.Wheels are actually 7.5 inches wide in both 18 inch and 20 inch diameters.
http://subarumedia.iconicweb.com/mediasite/attachments/19MY_Ascent_specs-FINAL.pdf
Thanks for trying. Not sure where they stamp it, but thought it was closer to the outside of the rim. Could be wrong, though...Did my best, had test drive by myself with my wife, pulled into parking lot pulled up on curb, locked wheel, crawled under, couldn't see anything on back of wheel due to caliper hiding backside of wheel. only way to see it, is pull wheel off.
This might be stamped close to the hub unfortunately.Thanks for trying. Not sure where they stamp it, but thought it was closer to the outside of the rim. Could be wrong, though...
Offset is 55Sure would be nice if someone would have a look at the inside of a rim and tell us what the offset is (ET)...
Thanks. Would like to confirm the 18s are the same.Offset is 55
DISK WHEEL-ALUMINIUM. 20X7.5J OFF55
DARK GRAY METALLIC (28111XC02A)
Ascent Parts
It's the sameThanks. Would like to confirm the 18s are the same.
