1 - 6 of 6 Posts
2019 Subaru Ascent Premium - When the radio is set to a comfortable volume - say 18, and you are running Waze through Apple Car play, when Waze interupts, it BLASTS. Have to turn the volume down to 8 to stay in the car. Any suggestions on how to equalize the radio and Waze volumes?
Have you turned down the volume while Waze is actually speaking? Mines a premium w/o nav and it stays on whatever volume I leave it but each function seems to have it own level that needs set.
You could also do what I do and just navigate per the map without voice. I understand if you鈥檙e most comfortable with the voice as well so you can keep eyes on the road.
There are multiple volume settings in the vehicle's head unit settings areas that enable you to equalize volume from various sources including your iPhone when using navigation apps. You can also adjust the volume WHILE the Wayz voice is speaking which is separate from the radio volume even though you use the same physical control. (volume knob on the dash or equvalent on the steering wheel)
Reactions: xydadx3
OK, so I'm ignorant. Please define "vehicle's head unit settings" and where do I find this? Thanks
Your manual is your friend. The Starlink manual specifically. Lots of great bathroom reading in there!
Touch the Home button on the head unit and the touch the "Setting" icon on the screen...etc.
1 - 6 of 6 Posts
