1 - 10 of 10 Posts
Today, my wife parked our 2019 Ascent, put the parking brake on, and turned off the car. Ten minutes later, she went to start the car and all the dash lights came on like normal while pressing the brake pedal. The car wouldn't start or even turn over. The fan was running in the engine compartment. We tried pressing the ignition again while pressing the brake pedal to turn it off, but it wouldn't turn off either. The dash continued to stay all lit up and if we put it in Neutral, it would tell us to put it in park to start it. After going through the same process for several more minutes, I took my key fob outside of the car about 5' away as my wife's was in the car still. It then started up immediately. I then tried it several more times on my own and it starts fine. Has anyone had this happen to them or have a solution or idea why it's happening? Thanks in advance.
Yes, once when I forgot to put the car in park when I turned it off, and twice when I tried shifting before it started.
One other person reported it happening when they pressed and held the start button. It's press, release immediately, and then wait for the computer to start the car a second later.
Hope that helps.
We have had this problem on both our 2019 Ascent and more recently our 2020 replacement Ascent. It just happened again last weekend. Pull into our driveway, put the car in park, and hit the start/stop button. The engine turned off, but EVERYTHING else remained on. Could still shift the car, AC still on, Radio still on, dash lit up like a christmas tree. Remained this way for over 30 minutes...pushing the start/stop button did nothing, holding down the start/stop button did nothing...as I was just about to disconnect the battery, I held the start/stop button down for 20 seconds or so until it turned amber again, then I shifted into drive, and back to park, hit the start/stop button again and it shut off.
Prior to this, in our 2019 and once before this in the 2020 this symptom would only occur for about 30 seconds before the system reset itself.
This is troubling behavior and clearly indicates (at least to me) a software problem that is not addressed properly yet. I have yet to call my local dealer as I know the outcome...they will find a bunch of fault codes, but nothing that would have caused "that" and give me the car back. I have the whole thing on video...again. I do love the car, but this is getting a little ridiculous.
That suggests a hardware problem. Possibly a shifter sensor. I'd love to see the video. I'll share it with some people I know, maybe we can figure out something.
Hi Robert -
You are right, I guess it could also be a bad piece of hardware. On the 2019, we were relatively certain it was somehow linked to the steering wheel being locked as it was a problem that was slightly different in that it was only experienced on startup (and yes, we know to take the tension off the steering wheel). This was on shutdown, so your diagnosis makes sense for sure. Happy to share the video with you. I actually have 3...the first two from when it happened and the third from 30 minutes later when I got it to shut down. Let me know how you would prefer to get the videos.
Hi Robert -
A YouTube link works, of that's easy enough. Probably too big for email.
My wife keeps having a similar issue where she shuts off the car, but the radio still keeps playing and there is a dash full of lights. It won't start back up, but if she closes the door, walks away and comes back after say 10 minutes, all is well, no radio playing, car starts fine. Unfortunately it happens when I am not home, so I can't troubleshoot. Did anyone come up with a fix or a lead here? This has happened about 3-4 times now and she is getting nervous about getting stranded. Luckily it has only happened when she was home.
The car isn't shut off. I do that accidentally. Car must be in park, foot on brake, and then turn off. Dash will shut off immediately, and radio will turn off when the door is opened.
It's also easy to smack the button when turning it off that you skip right back into accessory mode...been there, done that...fortunately catching it when it refused to lock. :)
1 - 10 of 10 Posts
