1 - 3 of 3 Posts
Discussion Starter #1
I prefer the inside of the car to be as dark as possible at night for better visibility. The Alpha Stelvio has a screen button that turns the screen off until you touch it again. In the Ascent I found this by navigating to this option. Not practical while driving. Is there a way to make a short cut to this option or is there a update that puts this option directly on the main screen?
There's no shortcut to do so that doesn't also mute/pause music.
But, you can dim it considerably by using the dial in front of your left knee.
Note also that if you had your interior lights at full brightness with the dial by the knee, that at least in Android Auto the map would never switch to night mode.
I was driving back in rural New Mexico where it is DARK and the interior map was so bright I had trouble seeing outside. Had to manually switch my map to night mode before I figured that trick out!
1 - 3 of 3 Posts
