Really funnyThey are on the turbo.
That's reassuring. kind ofIf I remember correctly they were missing, not loose. It was a thread here several weeks ago.
The turbo is mounted down low, front, off center. Very close to the exhaust manifolds to get a short run for turbine spool. You need to pull the plastic belly pan and all will be visible.Really funnyIn the engine bay?
Thanks! I figured it wouldn't be easy as i couldn't locate it from the top. I'll check them tonight.The turbo is mounted down low, front, off center. Very close to the exhaust manifolds to get a short run for turbine spool. You need to pull the plastic belly pan and all will be visible.
