1 - 5 of 5 Posts
Saw this TSB 04-22-18 9/17/18 on Techinfo:
This bulletin announces availability of a new electric power steering (EPS) rack assembly. The new EPS assembly addresses a limited number of customer concerns involving a rattling-type sound from the steering which may be heard when driving on rough roads.
The new EPS assembly was incorporated into production as per the table below:
PART INFORMATION:
Model Starting VIN
Ascent K3402362
Recently had this issue fixed after bringing it to dealers attention for a second time. Dealer replaced rack assembly after I took the service tech on a dirt road that I knew would make the noise. Having a TBS for it helped.
Thank you netcatz99 for posting this TBS confirming the problem.
Has the noise come back? My crosstrek was solved for about 6 weeks and its back in full noise again. Its the same rack across all models...
1 - 5 of 5 Posts
