This is an annoying trait of this car. Happens all the time to me.
it should open with either button IF the doors are unlocked when the engine is running. If the engine is not running and you have the fob on you it should open using either button.Hello all,
I recently had my car in for maintenance and where they updating the operating system on the heads up display.
Since getting it back, I've noticed that while the car is running but in park (doors unlocked) my car won't allow me to open the trunk - I just get th 3 beeps. I've tried using the trunk exterior button and the open trunk button on the dash.
Anyone's know if this is normal behavior? I feel like I would have noticed before if this had been happening, but I'm starring to question my memory.
Thanks in advance!
I've had that happen a couple of times on my '21....If you hold the button on the hatch itself for several seconds, it'll beep and reset itself. If that doesn't work, dealer may have to look at it.Hello all,
Thanks in advance!
Sounds like it needs to be reset. Go to the exterior back hatch switch and hold it in. Continue holding it in after the 3 beeps (don't let go). Within about 10 seconds the hatch should open. Close it with either button and it should reset to normal operation.Hello all,
Thanks in advance!
I had run down the battery on my 2022 Ascent Limited. We jumped it with my wife’s car, and I drove around for a half an hour then parked it. The next day, I was getting ready to load our suitcases in the back for our vacation and the tailgate would NOT open. We loaded them through the side doors, which was a pain. We set out and looked at YouTube videos and found a couple of solutions. 1. disconnect the positive connection on your battery. (but this MAY lose your radio station presets, etc. 2. BETTER: hold in the button on the trunk latch for a long time. My wife did this and it managed to open. I was not there when she did it, but it worked. We had the rest of the car unlocked at the time. In other words, I don’t know how long she had to hold this button in, but it worked. Note: most auto parts stores sell these gadgets that connect a 9 volt battery to your cigarette lighter; you plug it in if you need to disconnect the battery, and it preserves your radio presets & who knows what else. It sure beats having to re-enter all of your data manually. Good luck.Hello all, I recently had my car in for maintenance and where they updating the operating system on the heads up display. Since getting it back, I've noticed that while the car is running but in park (doors unlocked) my car won't allow me to open the trunk - I just get th 3 beeps. I've tried using the trunk exterior button and the open trunk button on the dash. Anyone's know if this is normal behavior? I feel like I would have noticed before if this had been happening, but I'm starring to question my memory. Thanks in advance!
Regarding your #1: it's a negative ground system, so for safety disconnect the negative terminal first, not the positive.I had run down the battery on my 2022 Ascent Limited. We jumped it with my wife’s car, and I drove around for a half an hour then parked it. The next day, I was getting ready to load our suitcases in the back for our vacation and the tailgate would NOT open. We loaded them through the side doors, which was a pain. We set out and looked at YouTube videos and found a couple of solutions. 1. disconnect the positive connection on your battery. (but this MAY lose your radio station presets, etc. 2. BETTER: hold in the button on the trunk latch for a long time. My wife did this and it managed to open. I was not there when she did it, but it worked. We had the rest of the car unlocked at the time. In other words, I don’t know how long she had to hold this button in, but it worked. Note: most auto parts stores sell these gadgets that connect a 9 volt battery to your cigarette lighter; you plug it in if you need to disconnect the battery, and it preserves your radio presets & who knows what else. It sure beats having to re-enter all of your data manually. Good luck.
Re #2, see my post above for what your wife did so you can repeat it.I had run down the battery on my 2022 Ascent Limited. We jumped it with my wife’s car, and I drove around for a half an hour then parked it. The next day, I was getting ready to load our suitcases in the back for our vacation and the tailgate would NOT open. We loaded them through the side doors, which was a pain. We set out and looked at YouTube videos and found a couple of solutions. 1. disconnect the positive connection on your battery. (but this MAY lose your radio station presets, etc. 2. BETTER: hold in the button on the trunk latch for a long time. My wife did this and it managed to open. I was not there when she did it, but it worked. We had the rest of the car unlocked at the time. In other words, I don’t know how long she had to hold this button in, but it worked. Note: most auto parts stores sell these gadgets that connect a 9 volt battery to your cigarette lighter; you plug it in if you need to disconnect the battery, and it preserves your radio presets & who knows what else. It sure beats having to re-enter all of your data manually. Good luck.
