161 - 167 of 167 Posts
I tow a PUMA 16DSX Ultralight. It's just me, my girlfriend, and my dog. I like the PUMA line mainly because of the space, price, and the fridge is HUGE for a ultralight
full gear, battery, tank on the tongue came out to 450lb tongue weight (tested and true) and the Ascent tows it with ease
Discussion Starter · #162 ·
A couple of mods I finally got around to doing. The bike rack was a long time coming, mostly because I kept going back and forth between replacing the bumper with 4" square tube or c channel and attaching a hitch or building a custom rack. The custom rack won out. $40 of angle and a day to fab and paint, I'm happy with it.
Wheel Tire Mode of transport Bicycle wheel rim Automotive tire
One unintended consequence was a lot of weight came off the tongue, too much weight. Considering the steel was 49 lbs and the bikes weigh 30 and 36 lbs, I didn't expect this much of a shift, but full loaded I was under 400 lbs where I'm usually at just under 500 lbs. So I transferred the spare to the front and today I fabbed a dual propane tank bracket and holder.
6502
6503
That should help a lot, I'm fairly certain I've got the extra hitch capacity now to even mount my generator over the tongue, but we've not needed to use it yet so I'll wait on any permanent mounting.
6504
The 30 amp weatherproof plug to me is a must, the factory setup is a joke, I had a colony of carpenter ants moving in the last time we went camping, so I ordered the plug and picked up the cord end from Lowes.
Discussion Starter · #163 ·
Camping update, we made it up to Topsail Preserve state park this year in the Florida panhandle. With a night spent in Oleno State park, we traveled a total of 450 miles and averaged 11.5 mpg at 60 mph. The towing was great, removing a lot of unnecessary equipment helped a bunch. The return trip I intend to try 65mph and compare mileage, my trailer tires are rated for 81mph so no worries there. I will probably also add a bit more weight up front.
Tire Plant Plant community Motor vehicle Vehicle
Wheel Tire Car Plant Vehicle
Sky Plant Plant community Natural landscape Branch
Plant Car Sky Tire Vehicle
Water Sky Cloud Beach Light
I bet that wind had a major impact for sure!
Wind may be the culprit more than weight
With travel trailers and cargo boxes, that's absolutely true. Weight is certainly a component because acceleration and extra load when moving uphill are certainly going to make the engine thirsty, but the effect of moving through the air puts significant resistance to forward movement. Add wind to that...and the more of a headwind it is, the worst it is and as speed rises, the effect multiplies..cha-ching. The same thing affects fuel economy of the bare vehicle. The faster you go, the more wind resistance there is that the engine has to fight against. The old laws of physics strike again!
Reactions: BiggieSub
