1 - 20 of 32 Posts
I usually do my own oil changes but when I travel there may be an occasion to have my oil changed by others. So after hearing all the horror stories about the transmission being drained accidentally I decided to add a warning sticker to the transmission.
Engine Auto part Vehicle Car Compact car
7124
you can purchase a sheet of sticky copy paper and print it out at home on a 8 1/2 X 11 sheet. The entire paper is sticky (protective backing is on for printing), or you could format it for four stickers on one print or you can send it over to Kinkos who can do this for you.
what do you meant accidentally drain? The dealer make this mistake?
No, but numerous quick oil change places make that mistake. I've watched or helped with over half a dozen Ascents alone where it's happened. :(
wow, i didn't realize they could make this mistake. i am putting a sticky note there myself. now, let me print this so i know where to stick my sign. I myself am clueless.
Make sure the sticker material is good for the temperatures that the transmission sees and is waterproof. I had this place make them for me.
Here is what I used for the sticker
Minimum order is for 12. What did you do with the other 11? If you would consider selling them, I'd like to buy one. Let's say, $5 shipped? (an envelope should do with a plain stamp) I can paypal or venmo.
2021 Ascent
I have just a few more left if anyone needs one.
Hi RobertD, I would like one as well. I'll PM you my address. Thanks.
After having gone thru oil change nightmare, I thought about welding up a metal bar which would bolt on, and block access to CVT drain plug. Instead, I am going to try a skid-plate specifically designed to bolt on to Subaru Ascent. Supposedly, skid-plate uses existing factory bolt holes and bolts. Thus no drilling, adding nuts or tapping.
Once I get skid-plate and have it mounted, I will post back with how it fit and how hard it was too install.
I strongly recommend Primitive Racing mid armor. You've likely seen the abuse I put my Ascent through. I wouldn't trust any other Ascent skids for that type of abuse.
1 - 20 of 32 Posts
