1 - 3 of 3 Posts
I’m looking to use the Ascent Premium with the 5k towing capacity to tow a travel trailer. Either the- casita 16’ with a 2480 dry weight or the Escape 17B with a 2640 dry weight.
would the Ascent be ok for that or do I need to look at say a Jeep Grand Cherokee or a Toyota 4Runner?
Thank you!!
2019 Ascent Limited (CWP)
HI and welcome to the forum! While I don't tow with my Ascent, there has been lots of discussion on the forum relating to the topic. Here is the link to the towing section with lots of active discussion: Towing
Bottom line based on the weights listed you should be find. Just don't forget to keep an eye on hitch weight (need to keep under 500lbs).
Best of luck!
Best of luck!
Thank you!
1 - 3 of 3 Posts
