Power for towing is fine. Handling is twitchy, not so good.
I am 75% through a trip from Pennsylvania to Yellowstone and Grand Teton, writing from KCMO. I am towing a Bullet Crossfire 1700BH with a 2021 Ascent Limited. At the start I used a tongue weight scale from etrailer.com to verify I had about 450 - 475# on the tongue with the trailer level. Weight on a CAT Scale was 2280# on the front axle, 3160# on the rear axle, and 4460# on the trailer's single axle.
The good:
- The Ascent handles the pull just fine. The biggest challenge so far was Teton Pass (elev. 8431 ft.), a climb of 2194 feet from Jackson, WY (elev. 6237 ft.) up a 10% grade. The Ascent pulled that climb without trouble, not even showing any increase in engine temp, even accelerating from my lunch stop part way up.
The bad:
- Trailer sway has been a real problem, at times quite frightening. The first day was had very heavy rain and gale force winds across eastern Ohio. Several times the sway got so violent that the whole Eyesight system shut off. I am grateful to the other drivers around me that kept away or I would have had a wreck. After that experience, I measured tongue height again with the trailer connected to the Ascent. Using the factory 4" drop tow bar, the tongue was almost 6" below horizontal. I replaced the Subaru tow bar with a Reese 2" rise bar, so I was within 1/2" of horizontal. That has helped a lot, but has not solved the sway problem. It still requires great care and gentle steering inputs. Sudden steering inputs will trigger severe sway episodes and eyesight shut down.
- The lane centering feature can be very helpful, but it can be dangerous at times. On curves it will sometimes cause the Ascent to cross the inside edge of the lane, triggering a lane departure warning, and potentially colliding with the vehicle in the next lane, or the barrier in a construction zone. When this happens, the steering input to correct can trigger a sway episode.
In summary, I know I am running heavy on this long trip, but I am within specs for both the Ascent and the trailer. Replacing the tow bar to level my trailer has helped, but not enough. I am hoping for the sort of good experiences Robert and others here have reported, but that is not my experience. At least not yet. Maybe folks here will have some tips for me.
Larry
The good:
The bad:
Larry
