1 - 15 of 15 Posts
Thanks. I watched that video on YouTube a couple times, it was pretty straight forward. I prepped all the tools ahead of time to make it easier.
This is easier than changing our brake drums from my 2008 Forester. And I had to install a tow hitch on my Forester as well..
Does the middle plastic cover snap back on to cover the whole setup once installed?
If you want to do a bike rack, is it Dremel time to create an opening and have a clean look?
Yes, the cover snaps back on for the clean look when not used.
No, can't just Dremel an opening because you need to insert the pin and clip needed to keep the hitch ball from falling back out. Well, maybe a larger opening that could slip over the ball and hitch, but with the amount of drop needed to get the proper ball height, I don't know if it would look nice.
There's a guy on the FB Ascent Group page who makes custom hitch covers out of the OEM part. He has two options, a smaller opening to allow access to the hitch and a wider cutout with access to both 4- and 7-pin connectors. I have one and it's really clean.
Good to know, thank you. I’m getting ready to buy the hitch kit (with Costco coupon) and was trying to decide if I should buy another OEM cover.
Here's the link to the post on the FB group. Not sure if you can access w/o being a member. If not, you'll need to join that group.
Discussion Starter · #9 · (Edited)
This is nice if you don't plan to tow often. You need access to the 7/4 pin plugs.
5684
The hitch cover for me costs
5685
5686
Needs more clearance for the breakaway chains, too. But that is, indeed, a very neat job on the cover.
Reactions: Ey31
Anybody got a pic of the cover with cutouts for chain clearance and the 7 and 4 pin connectors? Seems like there wouldn't be much of the cover left at that point.
That's pretty much the reason that I decided not to go this route, honestly, despite my preferences for a "neat" appearance.
Reactions: xydadx3
I’ve personally never made one that wide for fear the panel would be too flimsy. I have had some folks ask, and recommend they simply remove the panel entirely.
1 - 15 of 15 Posts
