1 - 3 of 3 Posts
My Ascent Touring model has the 20” tires. It came from the dealer with 39 lbs. of nitrogen in each tire - according to the menu display. I have not checked them with a tire gauge yet though. The sticker on the door pillar recommends 33 lbs. per tire. What are you folks running in the 20” tires?
I typically run the door indication or 1-2 PSI (cold) higher, depending on the tires...My Ascent is new so I haven't started playing around with it yet, however. My previous vehicle was a Grand Cherokee which was about 500 lbs heavier than the Ascent Touring. I ran at 38 PSI (cold) with the door indicating 36 PSI (cold). And that was with Michelin Defender LTX tires on 20" wheels.
33.
My tire gauge and the car's readings are very close. My Touring/20" stock Falkens came with blue tire caps (no idea if they were pumped with actual nitrogen... but regular air is 78% nitrogen anyway, can't imagine a huge difference in whatever they are going for there). Car reading on driving from dealership was 34's all around, so I figured that was close enough to 33 psi cold. I've since adjusted pressures as the startup/morning temps dipped through the winter and then back up again in the spring. For towing, I added 2 psi to the rears and haven't dropped it back down yet.
Except for towing, I adjust for 33 psi cold all around, whatever the season's cold startup temp happens to be. Seems to work, 12500 miles since September. Tire wear has been very even.
F.S.
1 - 3 of 3 Posts
