1 - 14 of 14 Posts
Hi everyone,
I have a Thule motion XT Large on my 2021 Ascent. I have some space to slide it either in the front or the back (without hitting the hatch door. I've attached two images of what it looks like on my stock crossbars. Can anyone with experience with cargo box recommend a position to minimize wind noise as well as giving the most efficient MPG? Should the cargo box sit more in the front or in the back? A thousand thanks in advance!
11455
11456
2022 Subaru ascent limited
So to be honest it does not really matter do what you like but I recommend in the front as to not disturb aerodynamics as much
Reactions: London
The directions for our Thule box was as far back as possible to help with aerodynamics. The windshield carries the wind over the box. Since we have a big sunroof, I didn’t want the crossbars in the center of the panels. So the front crossbar is set at the break between the the second panel starts. The rear crossbar is just after the end of the rear glass panel. The box is then positioned as far back as possible from there.
That's just what I was thinking of doing, so that the crossbars where as invisible as possible in regards to the moonroof. (we LOVE our moonroof!) And I think we'll probably only have the cargo box on there for long trips or when we head up to the mountain, but the crossbars I'll probably just leave on there all the time. Nice to know that that positioning works.
So ours isn’t as far back as it could but we didn’t notice any front of the box shaking. I’ve seen some to far forward end the wind is just catching it and making it shake especially if they are attached to flimsy crossbars.
11460
Thanks, for the explaination. I'll try that same setup. Thank you :)
yeah the moonroof is pretty awesome
Reactions: London
2021 Subaru Ascent Premium
Hi everyone,
For both MPG and good looks slam that bad boy as far back as you can without interfering with hatch operation. Putting your cargo box farther back also reduces cabin noise.
1 - 14 of 14 Posts
