1 - 7 of 7 Posts
My base model Ascent did not come with third row lights, instead I have plastic shields where the lights go. Does anybody know the part # for the lights? And are they plug & play? What I mean is, are there electrical connections behind those plastic shields? Any help appreciated.
Were the lights an option you could have added to the build of your basic model? If so, then I would think that wiring exists and the part is orderable as a kit of some sort. Maybe start checking to see if 3rd row light kits are a thing.
I think the 2nd and 3rd row lights are identical. Pull off one of the plastic shields off and look for wiring. If there is a plug, then remove one from the 2nd row and install it in the third row to test. If it works, order 2 more light fixtures.
I believe these are the parts. You might want to cross reference with your existing 2nd row fixtures.
That is brilliant, thank you! Will give it a shot and will post the outcome here.
Will do, maybe double check with dealership too. Thank you! Appreciate it!
Thank you for the quick response. The dealership never mentioned anything about not having 3rd row lights, I never noticed until about a month into ownership.
I’m gonna try what @rockthebeef suggested and see where that takes me.
Thanks again!
1 - 7 of 7 Posts
