Again, I don't see how. The sway bar bushing are just stiffer and the CVT insert just fills a hole in the OEM mount. Both the OEM sway bar bushings and this mount are designed to do the job with comfort as their priority over performance. All my products do it change how the car feels. Do the bushings improve road holding, I would say no, but they improve body roll. Does an external insert affect the way the CVT perfoms mechanically, no. Does it change the way the car feels under driveline weight transfers and "fake shifts" absolutely.I'm very interested in the sway bar and CVT bushings. My worry is with the powertrain warranty and potential issues with the CVT, and SOA having an out because of said bushings.
Ascent sway bar bushings always ship priority mail. I will make sure they get on their way today, should have live tracking on Monday at the latest.Just ordered front and rear 85D. Installing a 1” lift next week and hope to replace these at the same time! Thank you.
Chris sends them with instructions and grease to aid in the installation. Not too difficult if you're at least slightly mechanically inclined. Safety being the key: such as (a) when you're jacking up the car and (b) when re-torque the bolts you remove.I’m considering these. How difficult is the install? Any videos or instructions?
Thanks! Approximately how long did it take you to install?Chris sends them with instructions and grease to aid in the installation. Not too difficult if you're at least slightly mechanically inclined. Safety being the key: such as (a) when you're jacking up the car and (b) when re-torque the bolts you remove.I’m considering these. How difficult is the install? Any videos or instructions?
I have about 20 other projects before installing them. They're sitting on my kitchen counter still, lol! And, it's really cold over here right now. This Spring.Thanks! Approximately how long did it take you to install?
But ya have time for a new selfi for the Avatar.I have about 20 other projects before installing them. They're sitting on my kitchen counter still, lol! And, it's really cold over here right now. This Spring.
Someone should see if the 20mm STI bar will work with the width of the Ascent. The 85d bushing resist roll through the entire activation of the bar. A stiffer system through the whole range.I wish someone would release a sway bar kit to improve the handling. How much reduction in sway is there with the new bushing? Or is it just a harder initial set followed by the same wallow/roll?
I do. And I have an aftermarket RSB so my stock STI RSB should be up in my attic. I’ll check when I do my install of the 85D’s.Someone should see if the 20mm STI bar will work with the width of the Ascent. The 85d bushing resist roll through the entire activation of the bar. A stiffer system through the whole range.
That would be an interesting experiment. Anyone here have a WRX STI and an Ascent?
Hmmm......I may try the stiffer bushing.
