1 - 4 of 4 Posts
· Registered
First trip with the in-laws in back the rear climate control is blowing hot air! Temp was set to 68 & my first thought was there is something wrong with compressor. Turned it down to LO & air started cooling, now I'm thinking sensor is bad. After reading manual I look at sensor closely & wire is loose behind, not clipped in. Plugged that in & now it operates normally. What other plugs/ harnesses did they not get clipped in? Already heard of a few...
· Premium Member
Could you please post pictures of the sensor and how to check wires ?
Yes please share pictures of this as it could be helpful for others.
· Registered
Rear temp sensor located above cup holders in 3rd row-on drivers side. If you are experiencing any issues with temperature of air in that zone check this connection.
1 - 4 of 4 Posts
