The CX-9 will outperform the Ascent, even if you tune the Ascent for Sunoco 104.Wonder what fuel was used in this dyno. if 87 would love to know if this car responds better to premium 91/93. Probably no significant gains but im sure people are curious because of the cx-9
You can see significant gains with just a tune, what is your reasoning that a tuned Ascent wouldn't perform better than a stock CX-9?The CX-9 will outperform the Ascent, even if you tune the Ascent for Sunoco 104.
Ok, this was unfair. We have yet to see what gains are to come from tuning. I think I was just soured because I think the dyno numbers are high.You can see significant gains with just a tune, what is your reasoning that a tuned Ascent wouldn't perform better than a stock CX-9?
I highly doubt that. As far as performance they are literally neck and neck when it comes to 0-60,1/4 mile, and rolling start despite the mazda being 250lbs less. Tuning the subaru for highoctane will mostly likely set ahead of most of its competition and will probably be the only 3 row SUV that will even have proper aftermarket tunes right now. I can this thing getting about 25-30hp throughtout the power band as well as torqueThe CX-9 will outperform the Ascent, even if you tune the Ascent for Sunoco 104.
lol, yea your prolly right. I have a 2018 wrx now and Ive never tuned it but i hear the wrx can get like 40hp increase from tuning, which i think is what the ascent will get. 40hp doesnt sound like much but when the whole powerpand get it, it will feel like a different carOk, this was unfair. We have yet to see what gains are to come from tuning. I think I was just soured because I think the dyno numbers are high.
Has anyone contacted any independent tuners? Does COBB have anything yet? I am actually very interested in the tuning side. I have worked for over 4 years with a tuner who has cracked many Subaru ECUs that few other tuners care about. I'm sure he could do his similar magic here. My tuner usually has curves on the conservative side, and they usually match real world dyno numbers very close. What bugs me is over-inflated gains and optimistic dyno numbers and the runaway claims that result.
I mean everyone with a COBB AP on their WRX is 450Hp, right? Just ask them.
The Ford Explorer and Flex with their ecoboost engines actually have pretty reliable aftermarket tunes available, so there is a market out there for it.Tuning the subaru for highoctane will mostly likely set ahead of most of its competition and will probably be the only 3 row SUV that will even have proper aftermarket tunes right now.
Was not aware they had tunes available. Good to knowThe Ford Explorer and Flex with their ecoboost engines actually have pretty reliable aftermarket tunes available, so there is a market out there for it.Tuning the subaru for highoctane will mostly likely set ahead of most of its competition and will probably be the only 3 row SUV that will even have proper aftermarket tunes right now.
Are there tunes available?Was not aware they had tunes available. Good to know
I don't agree that Stage 1 gains are negligible, because I've seen 2015+ WRX's make 30-40hp/40tq just on a stage 1 dyno tuned. Maybe Off the Shelve tunes might be slightly negligible because your car might respond differently to a universal tune. But i will agree that Subaru did not leave 50hp on table, and im sure its going to take a few parts like intake, exhaust, charge pipe, Jpipe etc to even achieve some nice gains. I know perrin is working on the Ascent now so expect some cool stuff to be available. Im sure this car will have a ton of aftermarket support.Are there tunes available?
Keep in mind the COBB AP story for your run of the mill 2.5HT. The COBB stage 1 is basically remapping the throttle for CIA, or just remapping the throttle. Any "gains" on a stage 1 are negligible. A Stage 2, requires opening up the front end, and the back end. Stock manifolds and down-pipes, (j-pipe on these motors) exhausts would need to go and be replaced with (Supported?) aftermarket parts. That's is for a to get you the 40-50HP bump.
Any tune to the stock set-up will be little more than throttle-mapping and the resulting affect on the CVT. Add a 3-Port boost controller (who makes one? GrimmSpeed?) and you might be able to up the boost a bit and push a few more ponies. But, if you all are thinking Subaru left 50HP just sitting on the table and all you need is an AP to unlock it? I don't think so.
Time will tell.
That's right, but that's at the wheels where power is delivered to the ground. Factory specs measure engines at the flywheel, not taking drivetrain loss into account.So pausing the video it looks like only 220 HP ? Or am I wrong?
Dyno tuned, implies highly involved tuning, which would also require road tuning. This is not canned tune. This is a different story. If it's the right dyno and and a good tuner, then maybe at sea level. I live at mile high, so I tend to be less provacative with claims. And lets not forget, the Ascent ECU is not a WRX already crack.I don't agree that Stage 1 gains are negligible, because I've seen 2015+ WRX's make 30-40hp/40tq just on a stage 1 dyno tuned.
What is Perrin working on? Intake, J-Pipe?I know perrin is working on the Ascent now so expect some cool stuff to be available. Im sure this car will have a ton of aftermarket support.
I take the other road. Lock down the chassis and stabilize the CVT mount...Trickle down effects from my work on the 2010+ Outbacks.
https://www.ascentforums.com/forum/...uspension/1437-sway-bar-bushings-cke-ssp.html
https://www.ascentforums.com/forum/10-engine-technical-discussion/1525-cke-ssp-cvt-mount-insert.html
If you start add HP, the above will be a benefit.
