1 - 20 of 22 Posts
Yes, that refers to the head unit update, and, as far as I can tell, it's the December 23rd 2020 version. Emails are staggered over 4-6 weeks.
I got the email this week and updated last night. The link to instructions just tells you how to connect your car to wifi and then how to check for an update in the settings menu. Very easy. I'd upload them but am having network issues this morning. I'm sure you could figure it out on your own.
Read Only
I’ve been trying to update via a usb stick but the app (MacOS) says it can’t format the usb. I’ve reformatted the usb to both MacOS and PC but no luck with either. I’d rather not try the Wi-Fi from the car.
Any suggestion?
Thanks, Ed
The Harman software and head unit can be finicky about the USB drive that is used. You may try reformatting the drive (using MacOS) to Fat32 and then seeing if the Harman software will reformat and update to its liking. If not, try another brand/model of USB drive.
(My head unit rejected a drive after it started the update process, leaving me to believe I'd bricked it. I added a detour to Target to get a new drive and enough WiFi signal to run the Harman software again ... and things proceeded smoothly with the different make/model).
Read Only
Thanks, I tried both formats with no luck. I haven’t been able to get it loaded on the stick so I can take it to the car.
I picked up my Ascent on 12/31/20 so maybe I don’t need it. I should go look 🤪
The email notifications are staggered and come out over the span of multiple weeks. Kinda like some phone updates.
They likely space out the notifications to keep from completely overwhelming the servers more than they are already overwhelmed.... ;)
2021 Ascent
Lawd, the ole lady overheard me saying sun of a and next you know it there is my wife and two kids looking at me shaking their heads. 20 days old and I already botched up a simple update. Right now, I'm loading up the files to the new 3.0 USB Sandisk 65gb - fresh from Wally's. I did try using a 16gb 2.0 Sandisk and right away it started and then got to 100 percent complete on the GraceNote and the update failed and would come up with that pesky message about retry or shutting off in 666 seconds. Blasted Sassy B is trying to get me on the couch!
2020 Ascent Limited
EDITED WRONG INFORMATION HERE - Updated post below
I have used this for all of my updates and it has worked for every one. I had it laying around and decided to give it a shot. I was going to go to a USB 3.0 device, but I don't know if the car has USB 3.0, so there would be no real benefit.
SanDisk 32GB Cruzer Glide USB 2.0 Flash Drive - SDCZ60-032G-B35
From Amazon.com
Learn more: https://smile.amazon.com/dp/B007YX9O9E/ref=cm_sw_em_r_mt_dp_J38WRN7VBVN71YDC54GW
@E-EC-ECU I'd definitely use USB 3.0. A bunch of us have timed USB 2.0 sticks for the update, and the in car portion may take well over an hour (instead of 14-16 minutes).
So which specific brand and model USB 3.0 drive have you had success with, Robert?
Ooops, sorry, I thought this was a thread where I'd shared the links. Apologies... I use these, but they definitely didn't work until I reformatted them NTFS on my PC (they seem to get correctly set up on a Mac):
I have a bunch of them ranging 32GB to 256GB. I use a larger one in the car for music because it's barely visible (only the little plastic bump on the left sticks out). This is my "Car updates" one (with a lanyard and clip I attached to hang it to my wall near my computer between updates)...
12765
2020 Ascent Limited
Thanks! I knew my updates didn't take that long so I went to my car to doublecheck. I have the SanDisk Ultra USB 3.0 - 32GB.
It looks similar to the cruzer I mentioned in my wrong post above, so I went on Amazon and tried to find mine based on images alone. I was definitely wrong on that search :).
12767
lol, someplace I have the same USB 2 stick as in your post, and of course a plethora of others due to my day job... I made the mistake of grabbing the wrong one once... that's when I got the idea of a dedicated stick, since they're so cheap now.
1 - 20 of 22 Posts
