Planning a trip to Utah for this summer. Our plan is to base out of Moab and explore Arches, Canyonlands and Capitol Reef parks. Getting around I'm planning on trying to take "scenic" routes as much as possible, but nothing crazy. Mostly gravel roads that actually show up on a higher res paper road map I bought.
The one notable trail I'd really like to do is the Shafer trail to get to Canyonlands from Moab. I'm open to other suggestions for trails as well, but please keep in mind that I'm a novice off roader (lots of gravel driving experience though) and I'll have my family with me.
My main question is would anyone consider skid plates to be a requirement for the Shafer trail and the other driving I'm describing? I'm on stock suspension with Falken Wildpeak A/T tires that match stock tire diameter. Thanks in advance.
Hiya! I've done all of that and more.... but, first and foremost, for off-roading, I strongly suggest
ONLY the
Primitive Racing skid plates. For brush and forest trails, there's other brands - but I would
NOT use anything but Primitive Racing skids in Utah (and I've spent weeks overlanding there to come to that decision, lol).
MOAB...
Shafer Trail can be done
without skid plates, with care, slow speeds and watching what you are doing. I strongly suggest to turn around at the end of Shafer Trail (you won't see a big marker for it - look for a sign on the left that has all the BLM rules and warnings), because,
if you continue, you will be on...
...Potash Road - for that, I
suggest skid plates. (LOTS of care without them, and you can make it through). It looks like a breeze for most of it, but you will hit washed out and rough areas where you risk damaging your CVT on rocks. BUT, the views on Potash Road are spectacular, including some amazing vantage points overlooking the Colorado River. AIR DOWN for Potash Road.
BLM378
Also around Arches are things like BLM378, which I
suggest skids for, and suggest you skip if it's rained (everything turns to wet clay-like cement glop), but the views and especially the sunsets are stellar...
Salt Valley Road/BLM145...
Is safe for
non-skidded driving, and has some amazing (and free) camping spots all along it. The road is
VERY washboarded, so, air down for comfort and bring a portable pump to air back up.
There are side trails off it, that
definitely require skid plates, so, be aware of the terrain if you turn off. One such trail, which I wouldn't take in an Ascent without both skids and a lift is the
Tower Arch 4x4 Trail (do NOT take this without a second car with you, and a lift and skids) off Salt Valley Road... this hole is big enough to use as a sofa, and you'd have to drive up and over it.
The "easy" part goes from steep rock shelves into soupy sand... it's not "easy". This is over 15° and the drop offs get very steep. The sand "incline" at the bottom is actually the flat part.
Once you move outside of Arches and Canyonlands, right between the two (adjoining both) is...
Gemini Bridges...
Do NOT attempt Metal Masher Road, if you visit Gemini Bridges - I am not even sure if it's possible with my 2.4" lift and skids (I'll find out August 2022).
Stay on Gemini Bridges Road, and be VERY careful, and,
you can make it without skids (but I recommend skids, especially if you're newer to off roading and aren't yet the best at picking a line). The views are spectacular...
PART TWO coming soon...
If you've found this post helpful, and feel like paying it forward, please drop a few bucks on my Make-A-Wish Fundraiser (link in my signature).
