21 - 40 of 51 Posts
Discussion Starter #21
A couple of them have been long enough to do it ?
Thanks for the confirmation!
Wait...you live somewhere where traffic lights are more than 10 minutes long?!??!
Discussion Starter #23
Virginia Beach...
I think I may have just missed an emergency vehicle passing thru the intersections which wreaks havoc on the already excessively long signals. I can live with it in that case
Discussion Starter #24
Update: I used the video below to disable the noise for the seatbelts. Yes I wear my seat belt. It’s mostly for when a passenger needs to move a little more than a seatbelt allows to tend to kids in the back. We already know it’s dangerous, so at least now it’s not annoying too!
https://youtu.be/OYXeUlISB0c
Single press of engine start stop, click seatbelt 20x, 2 more presses to turn everything off, then start it up
Will you try your cruise to see if it still works? I read on another forum this truck also disabled cruise on the newer Subaru’s.
Discussion Starter #26
I almost forgot! Yes it works!
I never use conventional but I may check to make sure; I use adaptive all the time. I forgot I had even done anything different when I went for a drive last night.
Thank you!!! Hopefully I can try on my own Tuesday!
I've tried this a half dozen times so far on my Ascent with no success. How long after pressing the start button should I start clicking?
Discussion Starter #32
Patrick G.;50991 I've tried this a half dozen times so far on my Ascent with no success. How long after pressing the start button should I start clicking?[/QUOTE said:
I pressed and held the seatbelt button only a second or so after pressing start. It worked when I got just the right combo of starting/seatbelting/turning off and back on
Did you hold the seatbelt button the entire time, or did you press and release with each click? Also, did you release the seatbelt after the 20th click, or leave it buckled? I cannot get this to work in the Ascent no matter what I try.
Discussion Starter #34
Held the button the whole time. Released seatbelt at the end
Discussion Starter #36
You must have just held it lightly (not fully depressed) then? Because if I hold the button all the way down, I can't get it to click.
There was no “click” each time, just insert it fully and remove. Keep trying. It’s worth it!
I probably should’ve made an ascent specific video. Hindsight...
At this point, I think I'd need to see a video to be convinced this works on an Ascent! I've tried two dozen times without success:
  1. Have keys in my pocket
  2. Enter car and close door
  3. Press start/stop button once
  4. Within 2-3 seconds, hold down seatbelt release button and insert/remove seatbelt 20 times in under 30 seconds
  5. Press start/stop button twice
  6. Put foot on brake and press start/stop button once to start car
  7. Drive away only to find the seatbelt minder still annoying me
Discussion Starter #38
Sorry to hear that Patrick! I may have time this week to pull my battery cable to reset it, then I’ll be sure to record exactly how it worked in case I forgot something last time.
I hit the button twice to turn acc mode on. Then pushed the red button it and just pushed and pulled it out 20 times without releasing the red button. Turned car off and restarted and fixed it. It still beeps when you first crank car for a few seconds but then goes away and don’t come back on.
That did it! Two presses of the Start/Stop button to begin, instead of one. THANK YOU!
21 - 40 of 51 Posts
