Don't forget that the 1,000 mile break in is restarted.
What is the break in process for brakes?Don't forget that the 1,000 mile break in is restarted.
You need to do the same breakin as you did for the new vehicle...driving responsibly, operating the brakes normally without stomping on them (accident avoidance excepted, obviously) and without doing things like towing heavy loads, etc., for 1000 miles.What is the break in process for brakes?
Totally agree with you. I am in the midst of an email exchange with a representative from Subaru - offering a $500 coupon as compensation. I have a 2020 Ascent - with 14k miles and the vehicle has been to the shop twice for 1 rear rotor replace and once for front rotor resurface. Now we have a lot of braking noise, just waiting for the pulse/vibration to start again.I have 21k miles on my 2019 Subaru Ascent. So far, I have had to replace the rotors TWICE. I feel this is a design flaw and I can't continue to replace rotors for the remainder of the life of the vehicle. Subaru needs to acknowledge that there is an inherent design flaw with this model vehicle (loaner Ascent vehicles that I have had also have this problem). Since Subaru has not acknowledged this issue, I feel like taking my losses for the past year and getting a completely different vehicle (which will not be a Subaru!) Please keep in mind the rotors and pads were completely replaced at 9k miles. I am now at 21k with severe vibration and do not feel my car is safe to drive. The rotors are warping due to excessive heat and need to be completely recalled and redesigned.
Agreed! We need a recall or something. Getting 8K-10K miles out of a set of brakes is absolutely unacceptable.Subaru really needs to acknowledge that this is a problem that is NOT going to go away.
Damn dude, your heavy duty. That's some weight right there. Good 4 U Robert.Why would you make such an unsupported, unsubstantiated claim? At what time frame did you have yours replaced, and what steps did the dealership use to install the replacements?
At 21K, I had my rotors turned, and the pads re-installed per the new method, and they have been fine for the last 23,000 more miles (I am about to break 45,000 miles).
The stock rotors stopped this big beast behind my Ascent when I forgot to plug in the brake controller.
On the 2013 Outback I traded in I never touched the brakes. At all.Damn dude, your heavy duty. That's some weight right there. Good 4 U Robert.
I have the exact issue with my rotors, the breaks keep vibrating and didn't want to stop whenever my car down hill with no passenger or towing.Agreed! We need a recall or something. Getting 8K-10K miles out of a set of brakes is absolutely unacceptable.
My ‘14 Forester XT had 58K on it when I finally replaced the brakes and I could’ve gone another 10K easily. The dealer in fact said I could wait and I did them anyway.
This is nonsense and is such a systemic issue with the Ascents, Subaru needs a redesign + recall.
Brakes are one thing that needs to be 100% straight on any vehicle.
I chose R1 Concepts eLINE cross drilled front rotors with their Optimum OEp pads. I didn't touch the rear yet. I've had them installed for about 6 months and 5000miles so far.Which aftermarket brand did you use? How long have you had them on your car? Looking into going that route also at some point.
If this rotor and pad issue becomes more widespread, subaru may need to approachthis the same way they are with 2019 battery issue. That is to reimburse after market product. I just do not know how widespread it is.I just had the rotors and pads replaced under warranty. Warped rotors and cracked pads.
5800 miles on the odometer.
As soon as this Ascent is out of warranty, I am going aftermarket for pads and rotors. I had warped rotors, cracked pads and AWFUL stopping distance issues with my F250. The factory installed brakes (and subsequent warranty replacement "updates") were cr*p.
A post-warranty self-installed performance brake kit (rotors and pads front and rear) solved the problem.
Remember kids: Manufacturer's OEM suppliers are almost always the lowest bidders. My WAG is these rotors and pads are being made from Chinesium alloy.
YMMV.
I used PowerStop Z36 rotors and pads on my F250 and Z23 on the Honda Pilot. Had them on for over two years and 15K on the Ford, 32K on the Honda. The Ford weighed just under 7000 lbs. and the PowerStops cut my stopping distance by 70%.Which aftermarket brand did you use? How long have you had them on your car? Looking into going that route also at some point.
Was it all 4 rotors that were warped? I am 99% certain my rears are warped, but the one time I took it to the dealer they said they could not replicate it. Fronts squeak intermittently, but it's not as annoying as feeling (and hearing) vibration when braking - especially on long road trips. My Ascent is a 2021 with 2020 build date.I just had the rotors and pads replaced under warranty. Warped rotors and cracked pads.
YMMV.
Sorry. I should have been more exact. Front brake rotors and pads were replaced. Rears were deemed OK.Was it all 4 rotors that were warped? I am 99% certain my rears are warped, but the one time I took it to the dealer they said they could not replicate it. Fronts squeak intermittently, but it's not as annoying as feeling (and hearing) vibration when braking - especially on long road trips. My Ascent is a 2021 with 2020 build date.
