1 - 3 of 3 Posts
Am I missing something? Just picked up Sueberry and I can't just have the power pushed, seems I have to actually start her up to roll the windows down. Is there a way to work the windows without turning it fully on? thanks
Hit the start button twice without your foot on the brake. One push is ACC, two pushes is ON. Foot on the brake is start.
No, unfortunately it does not have the feature where you could use the key fob to roll the windows down before you get into the car, nor roll the window up if you left it partway open after you've exited the car. I did discover you can set a delay so that the windows will work for 5 minutes after you turn the car off (or have turned the car off from accessory mode), provided nobody has opened a door.
1 - 3 of 3 Posts
