2022 Ascent Limited CWP; 2019 Ascent Premium CWP; 2015 Outback Limited CWP
do those flaps use the same OEM holes?Very easy installation. No need to remove rear tires. Just use a small Victorinox knife with Phillips screwdriver. So you can make a right angle to tighten the screws. Took about 30 minutes.
Yes.do those flaps use the same OEM holes?
My car came with OEM mudflaps. They seem to work as intended, but I don't live on a gravel road. Rokblockx seems a bit larger, a good choice if you need them.Yes.
No need to drill. Use the original holes.
No obvious noise heard. Probably my music is often too laud.Does Rokblokz create any additional wind noise on highway speeds? I've looked at them in the past but haven't pulled the trigger.
