1 - 7 of 7 Posts
My butter fingers dropped a small socket in the engine bay. I heard to hit and roll on what I’m assuming is the under tray. Just feeling around I couldn’t find it. Is there a common point things roll to or a basic diagram on which clips are the correct ones to remove to get the under trey pulled down so I can get a better look where it might have gone?
If it was a 10mm then it was doing its annual migration. No harm no foul.
Otherwise I've noticed that these undertrays are held on by a few bolts. I've removed the two that cover the rear area to install some accessories. Fairly simple task for those.
Look up the Primitive Racing front skid plate instructions for the Ascent - you will find all your answers there.
2022 Ascent Onyx, Ice Silver
Good info, thanks!
1 - 7 of 7 Posts
