December 8, 2022 NHTSA CAMPAIGN NUMBER: 22V907000
Improperly Fastened Ground Bolts May Cause Fire
A melting ground terminal increases the risk of a fire.
NHTSA Campaign Number: 22V907000
Manufacturer Subaru of America, Inc.
Components ELECTRICAL SYSTEM
Potential Number of Units Affected 271,694
NUMBER IDENTIFIED SO FAR: 11
ESTIMATED PERCENTAGE WITH DEFECT: 1%
Summary
Subaru of America, Inc. (Subaru) is recalling certain 2019-2022 Ascent vehicles. The ground bolt that secures the ground terminal of the Positive Temperature Coefficient (PTC) heater may have been improperly fastened, which could result in melting of the ground terminal and surrounding components.
Remedy
Owners are advised to park their vehicle away from structures and to avoid leaving the vehicle unattended while the engine is running. An owner who notices or smells smoke coming from the dash or driver's footwell area should immediately stop operating the vehicle and turn the ignition switch to the "Off" position. Dealers will replace the PTC heater ground bolts and if necessary, replace the ground wire and the connector holder, free of charge. Owner notification letters are expected to be mailed February 6, 2023. Owners may contact Subaru's customer service at 1-844-373-6614. Subaru's number for this recall is WRL-22.
Description of Remedy Program
For all the affected vehicles, Subaru dealers will replace the PTC heater ground bolts and, if necessary, replace the ground wire and the connector holder.
MORE DETAILS
More details can be gleaned in the "Remedy Instructions and TSB" documents filed with the NHTSA and on STIS. You can find the public link below.
Chronology
Notes
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.nhtsa.gov.
DOCUMENTS:
WHERE TO CHECK IF YOU ARE A PART OF THE RECALL
Everyone, this is the most accurate place to see if you're a part of the recall:
QUESTIONS AND ANSWERS:
I will be using this section to address the most common questions I see.
Summary
Remedy
- As a precautionary measure, it is highly recommended that owners park their vehicle away from any garage, car port or other structure until this repair is completed.
- Additionally, owners should never leave the vehicle unattended while the engine is running until this repair is completed.
- If an owner notices or smells smoke coming from the dash or driver’s footwell area, the ignition should be placed in the “off” position and the vehicle should not be operated. If this occurs, the owner should immediately contact Subaru’s Roadside Assistance or the nearest Subaru dealer for assistance.
MORE DETAILS
Chronology
- January 9, 2020 - Air tools introduced to the production line (replacing battery tool)
- January 11, 2020 – Subaru received the first technical report exhibiting smoke from the driver’s side interior cabin
- September 29, 2021 – Subaru received the first technical report involving fire damage. While a vehicle inspection identified the area of origination, a root cause could not be determined due to the significant damage caused by the fire.
- February 24, 2022 – Subaru received the first technical report exhibiting smoke on a vehicle produced after the Jan 9, 2020 tool change
- April 29, 2022 – Subaru changed line tooling to DC tools capable of detecting torque and rotation angle
- May 2022 – Subaru received the first technical report from the U.S. market involving fire damage on a vehicle produced after the Jan 9, 2020 tool change.
- May-July 2022 Subaru conducted testing and evaluation to determine the specific conditions required to generate the heat necessary to cause the melting conditions being observed. It was determined that contact surface area was the primary condition. Low torque was a secondary condition.
- August 15-30, 2022 – Subaru conducted a field evaluation study to understand the potential scope of the issue Part 573 Safety Recall Report 22V-907 Page 3 The information contained in this report was submitted pursuant to 49 CFR §573 beyond the few incidents that were reported.
- December 1, 2022 – Out of an abundance of caution, Subaru decided to conduct a voluntary safety recall. Subaru is only aware of 11 technical reports in the U.S. market. Subaru is not aware of any crashes or injuries resulting from this condition.
Notes
DOCUMENTS:
- Recall Acknowledgement
RCAK-22V907-6253.pdf 646.319KB - Defect Notice 573 Report
RCLRPT-22V907-5845.PDF 214.751KB - Subaru - Subarunet Announcement - December 2022
RCMN-22V907-8669.pdf 210.516KB - Subaru - Ascent Recall Announcement - December 2022
RMISC-22V907-1444.pdf 126.867KB - Remedy Instructions and TSB
RCRIT-22V907-2969.pdf 15354.098KB - Subaru - Subarunet Announcement - December 2022
RCMN-22V907-6697.pdf 188.33KB
Vehicle Recalls
Visit Subaru.com for up-to-date & accurate information on vehicle recalls. Check VIN number for all available recall solutions. Your safety is our priority.
www.subaru.com
- NHTSA is the second most accurate place to check (virtually always equally as accurate).
- The MySubaru app may take a while to update but will eventually be correct (it usually updates after the Federally mandated postal service delivered physical printed notification is mailed).
- CarFax and the likes are often wrong and base it off year and model.
QUESTION | ANSWER |
My 2019 Ascent was built before the tool change suspected to cause the issue - am I a part of the recall? | Most likely. Try the link above and enter your VIN. Like mine (built May 2018), though your Ascents ARE NOT built with the tools Subaru identified as having the problem, Subaru "in an overabundance of caution" is including ALL Subaru Ascents up to the tooling change, in the recall - because that's how they handle safety. To date, they've identified no Ascents in our production time frame that are affected, but, we're still getting the remedy applied. So, while (to date) there were no problems identified with the early Ascents, the remedy for the rest is better, and we're getting it installed as well. |
When does the PTC Heater turn on? | The PTC heater activates when the car is first started and the coolant isn't up to temperature, as well as when idling in extreme cold when engine temps are too low to handle heating the cabin (it doesn't turn on just when idling). So, in other words: if your car is maintaining 195 degrees coolant when idling, then, the PTC heater would most likely only come on when you start the car with the heat on any setting that (a) was warmer than ambient/cabin temperature and/or (b) when recirculation wasn't on, and outside air was lower than the set temperature. If heater coolant temp is at the Subaru 195 (+/- 1-5 degrees), the PTC heater most likely will not turn on. |
