I ordered one (along with a few other things) a couple days ago and was told it would be here today, they double checked to make sure they could get everything too. So I guess we'll see if I actually get the call today or not.Most of the online retailers indicate the bumper cover part is on back order with no ETA, and that's been the situation for the past couple of weeks. Anyone bought one recently?
I will probably install this one when it becomes available, but I would much rather have the option for a black rubber cover vs. the chrome.
Why are you guys mentioning bubbles? It's just an aluminum part with strips of (probably 3M) adhesive tape to stick it down. Sure there may be bubbles because of the nature of the spongy tape not being perfectly flat but you'll never see or even know they are there. Put some good pressure on it as you're pushing it down and you'll probably squeeze some of those bubbles out too.we ordered ours with so hopefully it comes on there.
its a super easy install just make sure the car is super super clean and put it on like a sticker, just make sure to keep your fingers off of it, some bubbles will come out with time in the sun but most wont so take your time and work middle to the ends.
Unless there's something I'm missing, which is possible, I don't see the concern over the bubbles..?
Ah, nope. It's an actual piece of aluminum... pretty sure it's aluminum anyway, I guess it could be plated plastic. But it is in fact a solid piece that sticks onto the top of the rear bumper to protect the paint.I ordered one (along with a few other things) a couple days ago and was told it would be here today, they double checked to make sure they could get everything too. So I guess we'll see if I actually get the call today or not.
I thought that is was still a clear 3m type thing, that is what I have on my STI
It's not a clear bra or Paint protection film.
I'll let you know exactly what it's made out of when I get the call. Or if someone else who already has it installed could let us know if it's really aluminum or plated plastic?
It's NOT aluminum :crying: It's plastic.Ah, nope. It's an actual piece of aluminum... pretty sure it's aluminum anyway, I guess it could be plated plastic. But it is in fact a solid piece that sticks onto the top of the rear bumper to protect the paint.
You can get it for around $65.Hmmm. $85 for that? At least it's recyclable plastic (per the pictures). Wonder if someone will come out with some better alternatives in the after market?
Are you sure it's aluminum? All prior reports indicate it is plastic with a metal finish and the earlier pictures in the thread show that it is stamped with a "7" plastic recycling symbol.It’s aluminum- I have it installed on mine. Very easy install - peal and stick. Make sure surface is clean and dry.
Yes, it looks exactly like aluminum when it's on the car, they did a very good job there. But it is indeed plastic. See the photos I attached above. There was even a small section on the underside of ours where the plating chipped off.It’s aluminum- I have it installed on mine. Very easy install - peal and stick. Make sure surface is clean and dry.
