1 - 4 of 4 Posts
I have noticed that when rear door are opened there is a strange popping sound. I checked 2nd Ascent on the lot and it made the same sound. Door function normally (other then popping sound).
what is this sound?
is this something I should worry about?
Sometimes that sound is nothing more than the latch rod being loose, which can easily be tightened with a wrench. You could do it yourself. You should be able to see the rod rock a little when you move the door back and forth when opened. That happened on my brand new Camry. That would be the simple solution. Your problem may vary.
1 - 4 of 4 Posts
