1 - 5 of 5 Posts
I'm getting my ascent and trailer set up for towing now, and the Tekonsha P3 and Subaru harnesses are spliced and it shows signs of life.
The fuse holder that's part of the Subaru harness has a clip. Is there a designated location for it under the dash somewhere?
2019 Ascent Premium
There might be, but I’m unaware of where it would go. I imagine the fuse holder is one that is used across a variety of applications. I just wrapped the entire length of the spliced wires of the harness to the P3’s harness with electrical tape, then coiled it under the dash next to where the Subaru’s connector is located. Since I mounted the controller bracket on the fuse access panel cover, it tucks in there very nicely. Since I don’t tow often, I also purchased from the dealer a replacement fuse access panel cover for less than five dollars, which I use when I’m not towing, storing both the cover with the P3 bracket installed, and the P3 in its case, in the storage area in the back. That way I don’t have to deal with the occasional “knee strike” on the bracket when I’m exiting the car.
2020 Subaru Ascent Touring
Just purchased a 2020 Subaru Ascent Touring with Subaru Factory hitch receiver installed. They told me at the dealership it has a trailer brake controller built-in, find it under the dash on the left side (I don't see it). Then I found a package in the glove box marked "Trailer Brake Controller", a pigtail square connector? I am getting my trailer next week. Q: Will the Subaru apply a signal to the brakes on the trailer each time I step on the Subaru brakes?
You have a connector in that location to plug in the brake controller of your choice. The dealer misspoke...there is no built in brake controller in the Ascent. There are a few vehicles out there that provide that (mostly pick-em-up trucks and large SUVs), but it's not typical for mid-sized vehicles. You must buy a brake controller and install it before taking your new trailer on the road to be legal...and safe.
1 - 5 of 5 Posts
