I'm having a issue where when I use the hold open latch on the pump, it will pump about 2 gallons, then the pump will auto shut off. Restart it, pumps about 2 gallons, pump will auto shut off again. I've tried 3 different gas stations, and at least 2 different pumps at each station. Anyone else having an issue similar to this? I've resorted to leaving the vehicle in accessory mode, so that I can check the gas gauge to see when it is actually full.
