1 - 10 of 10 Posts
· Super Moderator
Well I just found out the hard way a Tribeca holds up very well to a sheet of plywood on the interstate…
One of my Easter weekend nice-weather projects included expanding our chicken coop. My wife bought 6 chicks which she really wants out of the house soon. The coop is already at capacity so It required (1) 4’x8’x1/2” sheet of plywood and some miscellaneous other wood for expansion. Well, we all know how well a full sheet of plywood fits in the back of an Ascent (it doesn’t) so I texted a friend to borrow his trailer. I picked it up and the Ascent pulled it nicely; I barely knew it was there. That was Saturday.
FFWD to Monday. I pulled the trailer to work with some scrap chain link fence to take to the dump before returning the trailer after work. After dropping the scrap off, I took the interstate to get back to work. As I accelerated into the highway I heard and felt a thud! I could see a sheet of plywood hit the raised rear wall of the trailer then go airborne right in front of the car behind me!
Of course I pulled over immediately and looked behind me where only 1 other car was pulling over, thankfully. The driver was ok and was already inspecting her Tribeca when I walked back to check on her. The only damage the Tribeca took was the passenger side mirror broke! I was amazed and can only assume they use a different sheet metal on that car than the Ascent. My Ascent gets a scratch and dent if I look at it too hard!
Moral of the story: be extra thorough inspecting your loads, especially when towing. My friend had put the plywood in the bottom of the trailer to move mulch and I just assumed it was fastened to the trailer. Apparently not. Could've been much worse!
· Super Moderator
Wow....'glad there was no injury there and only minor damage to the vehicle that got whacked! I'm sure your friend will, um...be informed...about having loose sheet goods in/on a trailer and why it's not a good idea!!!
· Super Moderator
· Super Moderator
Wow so I just reviewed my dash cam footage. The look on my face as I watched it unfold in my rear view mirror was priceless. No I’m not posting it so don’t ask! 😜
Literally 5 seconds before the plywood went airborne a Volvo wagon was RIGHT behind me. They changed lanes to pass me, allowing a bigger gap between myself and the Tribeca. The plywood looked like it stayed airborne right in front of the Tribeca just long enough for her to slow down and mostly miss the impact.
· Super Moderator
You mean to tie the plywood down? Had I known the wood wasn't attached to the trailer I would have strapped it down.
The trailer was empty with the exception of the wood that was lining the trailer. I falsely assumed that wood was secured to the trailer; it looked like it was.
When I moved the piece of plywood and boards I needed for myself I ratchet strapped everything down tight.
1 - 10 of 10 Posts
