1 - 13 of 13 Posts
This is just a friendly public service announcement regarding the battery life in the key fobs for those with a push start Ascent.
I own a 2017 Impreza with the same fob style. The build date is 4/17. Lately I have been getting the "battery low" indicator on the MFI about the fob. Now I have two fobs, just like in the Ascent. I keep one in the car (yeah I know what you think, but I don't care) and the other more than twice the recommended distance of 6.6ft away from the car. Even with swapping the fobs, I would still get the "batter low" warning when starting the vehicle away from my house. So, it seems to me that the battery life can be used up in about 32 months, which is near the manual's statement of 3 years. I know how to enter the car with the key, and also start the car with the fob if the battery is dead. If you do not know how to, please look in your manual.
At any rate, since I have 4 fobs and soon to be 6 fobs, I figured it was time to have some spare batteries on hand once these things start to die. I ordered the 10 pack from Amazon:
The replacement process takes all of a minute with a small flat head screwdriver. No need to go to the dealer. If people can keep jumper cables, spare wiper blades, a tow strap, etc....why not a spare fob battery on hand?
I had to replace both of my FOB batteries at about 12 months for some reason. I was getting weirdness with the locks and intermittent starting problems. New batteries fixed it.
Cool that it's the very commonly available and widely used CR2032. I already have a bunch of those on hand. My previous cars used CR1632 batteries which were more difficult to find and not usefully in anything else I have.
Excellent advice, but, no screwdriver is needed. The new FOBs come with everything needed except the battery for battery changes.
NOTE: when I reference top and bottom, I am refencing hanging position. Reverse those directions as necessary (I explain which I mean in the video)
RobertM, thanks for the video. I just replaced mine.
For everyone else, if you replace you key fob battery notice that Robert has his over a table surface. I highly recommend this after searching all over my chair and my person before finding the little shiny button with the horn on it. Thankfully I found it. Now I know why it is called the panic button!
If you're like me and only use one FOB. Turn off your spare FOB, and save the battery from excess drain. That way your spare should still work when you really need it (provided the lithium battery hasn't expired due to age).
Basically it turns off the little proximity radio beacon your FOB is constantly sending out.
Today is day 1000 of owning my Ascent! Well, to remember this date it finally told me my fob battery is getting low. Thanks for posting the type of battery required so I didn’t have to search much!
So my question. I got the warning message, had the card since May 2019 so not a big deal. I replaced it with a new Energizer CR2032 battery. It works fine, but twice this week I've gotten the warning message again with a battery I replaced 2 weeks ago. I know I didn't put it in wrong because the fob works. I did just order a Duracell battery just in case I just happened to get a bad battery but I am now worrying that maybe the warning is indicative of some other issue?
I'd start by testing the FOB battery. I've gotten a few bad ones every now and then, regardless of brand. Also, is the other FOB nearby? Have you changed that battery yet?
No the other FOB is not nearby. thanks
And now I feel stupid. Just double checked and you are right the other FOB was nearby. It was in the thing that has my book in the glove compartment! Thanks very much not only did you solve the question of the battery warning, you alerted me that I had the FOB in there which is not a good thing.
thanks again much appreciated
1 - 13 of 13 Posts
