1 - 12 of 12 Posts
Turning on full auto for the HVAC is easy, just press the auto button. Disabling it on the other hand is confusing. Is there a correct process? This is what I have found so far:
1) Press auto button, this disables full auto and puts it in limited auto mode
2) Turn temp all the way down to "LO"
3) Disable recirculate (it turns on automatically when going to "LO"
4) Press the fan button to change the blower to the floor
At this point auto finally shuts off on the dash.
Pressing mode when in full auto mode or auto mode? When in auto mode it does nothing, auto stays on and the direction of the fan just changes. I want to say I tested this with full auto and it didnt change anything, but its been a couple days.
Just tested. With full auto on, if you press mode it goes to "auto" mode. From there, you have to turn down the temp to "LO", adjust the fan, and turn off the recirculate/AC (if on) to get "auto" to turn off. Pretty crazy!
After adjusting the fan speed and direction, is there even a need to turn off auto temperature control?
I don't know why my car would be different than yours, but here's what I got.
If your goal is to go from Full Auto and get back to just Auto, hit Mode. That's it.
If your goal is to go from Full Auto and get back to nothing (no Auto, just a fan and temp), hit Mode, turn fan to lowest, unclick recirc, and unclick AC. (No need for mucking with the temp knob at all.)
F.S.
F.S.
Tested this out and you are close. In my case the recirculation is not on, so your steps don't work. But, if I toggle it on then off the rest of your steps work. Turning down the temp is what forced on the recirculate
1 - 12 of 12 Posts
