1 - 12 of 12 Posts
Sometimes the parking brake seems to know when I want to go and it releases by itself if I engage R or D. Then sometimes it won't release until I press the button to release it. I have yet to understand if there's a pattern here. On a side note, I also sometimes feel like the car is so intelligent that it has a sense of humor and is toying with me...:D:oops:
The parking brake will release if you give it a lot of gas - I know it is in the manual as such. I've done it a few times but I have trained myself to always reach for the button as I park and as I leave.
@Janner if you meet all the prequisites it’ll turn off when you just tap the gas: Doors closed, seatbelt on, gear shift in drive, brake and start/stop pressed if remote started...I probably missed something.
@Eroi50 I think you’re right. The car is smarter than us and it likes to make sure we don’t forget!
As far as I know we haven’t reached a complete consensus about what causes the parking brake to engage automatically either...
The parking brake engages automatically?
It can, after you put it in park or are stationary in drive for too long. I’m still not 100% sure what conditions have to be met for it to engage itself so I still check it every time.
Thanks for the tip. I found two references in the manual. Are there other situations?
Page 345: "When the electronic parking brake has not been used for a long period of time, the electronic parking brake may operate automatically after the ignition switch is turned to the “LOCK”/“OFF” position. This occurs due to checking the proper operation of the electronic parking brake and does not indicate a malfunction."
Page 367: "In the following cases, after the vehicle has been stopped by the Re-verse Automatic Braking system, brake control is released and the electronic parking brake operates." It goes on to list the conditions.
As for the original question, I don't see any indication that the parking brake should release when you shift out of park. It should stay on until you press the accelerator or turn it off manually. If that's not the case, something is wrong. (I think)
It's either determined by this:
1378
Or by the numerous scenarios on pages 344-347 (yes, 4 whole pages on it) in this version of the online manual, plus the extra pages in the Eyesight manual related to it.
I am not going to try to decipher the 9 or 10 pages of scenarios, so, I will go with option 1 above instead, and just try to remember to turn it off before I drive. :ROFLMAO: :unsure:
Seriously though, I am not going to try to summarize it.
Unless maybe it wasn't activated as a parking brake function? EG: Auto Vehicle Hold activated it, or Parking Brake Check function activated it?
Pretty sure AVH disables (inactivates) if the car is shifted into park though... may try some scenarios tonight, if work permits.
I hadn't thought to check the eyesight manual. Indeed, the car will also engage the parking brake automatically after coming to a stop due to pre-collision braking (much as for the reverse automatic braking) and if you let adaptive cruise control bring you to a stop. As for the latter, there is interplay between the stay-stopped function and the automatic engagement of the parking brake.
I’ve used AVH several times and it remains active until the AVH engage/disengage button is pushed. This is true after engine shutdown and re-start. Once turned on, it stays on until turned off.
I think you misread the old conversation. There's a difference between the system being on and in stand-by ("disengaged") and it being turned off. You are correct that the system state (stand-by/on vs off) remains the same between starts, but that wasn't the point. ;)
1 - 12 of 12 Posts
