1 - 4 of 4 Posts
Is there a way to turn on the electronic functions without starting the engine? Back in the day you could turn the key halfway so you could open or close the windows without actually starting the car.
Is that possible on the ascent? Seems as soon as you tap the start button the engine turns over...
The one thing I like is that the windows will still operate for a few minutes even after you turn off the car. I use the single press to listen to music on a USB stick when the car is off. Two presses to adjust the windows or moonroof. Just keep your foot off the brake and you can make it all work!
1 - 4 of 4 Posts
