As title says...
Local service company (dealer is long way away) drained Transmission fluid, instead of Engine Oil.
Followed by adding required engine oil to already oil full engine.
For what it is worth, service company did successfully change engine oil filter.
Amazingly, Subaru Ascent ran several miles without a hint of problems.
Then came first sign of problems, a slight whining noise from right front. Still Subaru drove on.
Followed by all sorts of warning lights, Check Engine, Temp warning on transmission, Brakes, Rear assist braking, Eyesight system disabled, Vehicle stability(?) failure, etc.
Next was randomly intermittent brief screech noise from right rear tire area. Accompanied by a jitter of Ascent.
Naturally, I am very concerned about CVT being permanently damaged having been run without fluid. Along with engine being damaged due to being 4-quarts over-filled. Over filling at least on engines where crank ends up slapping oil, causes oil to froth (air bubbles). Resulting in damage to bearings. Possibly piston rings and turbo-charger.
Question is: Anyone had same mistake made and what was outcome?
PS: This is not Subaru's fault in anyway. Local service company is totally responsible. They have changed oil & filter before without problems. This time, a new hire did work, and messed up big time.
