I bought my MY-22 used a few months ago. It had just over 15,500 miles on it. My first long-ish trip, I got 26.7 or so mpg. Great, I thought. Ever since, I can’t get that again. Several trips and just over 17k on it now. Most of my trips have been around 100-150 miles round trip. Some more, and many less. I have been reading a lot of the “mileage” threads here. I drive like the proverbial “old man.” If I go over the limit, it is no more than 2 mph. Typical is right at posted speeds…I love getting great mileage! Anyway, on the freeway the other day, I was right at 70 and noticed the rpm’s were at 2k on the dot. A bit high, I thought. So I kicked it into manual and the shift indicator was showing “7.” I kicked it up to 8 and the rpm’s fell about 250, to roughly 1750 or so. So I experimented a bit and every time, when switching from auto to manual at 70, my rpm’s dropped once I went into 8th “gear.” Why? Why would I be cruising in 7th gear and not at the best possible gear ratio? Is this normal? Should I be having a conversation with my dealer? At the time I noticed this, and every other time I tested it, I was traveling on flat level ground.
Now, I find myself driving at highway speeds, in manual, 8th gear. It sucked the first time I took the exit ramp and started off from the stop light…forgot I was in manual and was a bit surprised to be reving near redline (trans went into 1st gear when stopped) while getting up to speed.
Thanks.
Thanks.
