forgotten? possibly, but i bet there are dimples that you can feel for in the bumper.I just realized that my ascent doesn't have mounting for front license plate. Did Subaru forget this?
There's two dimples as mentioned in the next post for you to screw into.I just realized that my ascent doesn't have mounting for front license plate. Did Subaru forget this?
Yep, or from any dealership for about the same price. I suggest little rubber feet on the bottom part of it so it doesn't bang against the bumper, since it's only secured from the top.Front License Plate Bumper Mounting Bracket for SUBARU
Ebay Item# 271540451558
Mounts with 2 screws in dimples. Rubber spacers. Solid. Looks good.
Easy solution
Front plate holders are an accessory. In a state where the front plate is required, typically the dealership puts it on and then charges you for it. But some of them don't. As others have mentioned, front plates are not required in all states, so we don't bother.I just realized that my ascent doesn't have mounting for front license plate. Did Subaru forget this?
The screw holes in the rear are little plastic inserts. I believe they can be changed out if they ever happen to get stripped. I bought a set of black license plate screws to go with black silicone frames and California black plates. The screws I bought had a slightly courser thread and larger shaft than the stock screws IIRC, but they went in just fine and are very secure.So bumping an old thread. Not in need of a front license plate mount, but what is the screw size for the license plate for the rear? Is there a suggested place to get them online, or just take one that is in it and try to get it matched with a stainless steel one at a hardware store? Replacing paper tag with license plate and would like to use 4 screws instead of just the 2 it came with, and prefer stainless. I've found some info on other Subaru models on some other forums, but wasn't sure if they were common among the models. All my other vehicles used bolts, but seems Subaru uses screws.
Thank you
screws:
https://www.amazon.com/Revolution-Car-Badges-Fastening-American/dp/B0769MFR7L/ref=sr_1_fkmr0_1?ie=UTF8&qid=1542231013&sr=8-1-fkmr0&keywords=Black+License+Plate+Screws+for+Fastening+License+Plates%2C+Frames%2C+and+Covers+on+American+Cars+and+Trucks
frames (black is out of stock):
https://www.amazon.com/Rightcar-Sol...ame+-+Rust-Proof.+Rattle-Proof.+Weather-Proof
I had that Subaru one on my Outback. It was fine and did its job over the years. It was pretty floppy if you touched it due to there being only two rubber spacers, but it was too costly to just chuck in the garbage so I just stuck with it.Or you can just get the factory Subaru front license plate frame. There are two small divots in the front bumper that will show you were to start the screws. This plate has two rubber bumpers that offset it from the painted bumper, minimize any possibility of damage. This is the official Subaru part for Ascent front bumper license plate frames.
https://smile.amazon.com/gp/product/B00IW33UPO/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
screws:
https://www.amazon.com/Revolution-C...rames,+and+Covers+on+American+Cars+and+Trucks
Not that I've though much about it since installing, but I really like the silicone frames. They blend right in and cover up the sharp edges of the plates. I should get a set for the wife's car...Finally got the Rightcar solutions silicone license plate frame in black. Got a notification email about a week or so ago that they would be back in stock, so I ordered one. Got it yesterday and installed on my wife's Ascent. Seems like a nice accessory and should keep the plate from scratching the vehicle. Hopefully it tolerates temperature extremes well and doesn't glue itself to the vehicle.
Still need to pick up some extra screws to use in the 2 holes at the bottom of the plate.
Did you ever figure this out?Just curious if anyone know the standard license plate screw size? Just noticed the dealer put on 4 nice rusted ones.
I ordered this as well for the front. I'll take my own pic once I get mine in (just ordered finally). But, here's what it looks like.I have this on my Ascent and love it: https://www.mycarworx.com/store/responsive_site/Ascent_2019_License_Bracket_Frame.html
